whats wrong with it??
from where?
Speakers go crackly intermittently, I've tested it with another amp so it's not the speakers that are stuffed, amp may need some connections soldered or something
Got it from jb
no, he already beats his brother or atleast until mid third gear lol.. lol he has an FP green turbo on the evo, his brother is at 350kw or something and daniels at 223kw i think.. its quite amusing watching daniels car just chase things, its fkn lightning quick. after i drove his evo, its why i bought one
doesnt even need cams, more boost and he will be at around 300kw, i dont know what he's waiting for!
How much boost is he running now?
300kw at at the wheels in an evo is no easy feat.
There were a few around my area with big turbos and 2.4 strokers, cams etc makin around 320ish kw at the wheels.
Only running 19psi witch is very low in the evo world..... Cams, boost should place me in the HIGH!!!! 200kw...... I have all the supporting mods so why the bloody hell not... And I'm getting transfered to a closer store for work aprox 2km away from home so.......MEH
You got narre? Awesome
I'm very farmiliar with the evo world, I know them pretty well, that is low boost you're running. Nah all good man, hope you achieve your goals. I'd love to see the final results, post them up here when you get it all done.
Isn't 17-18PSI stock? (Either this or 15-16?) Or is it different for 6's?
Didn't know you had an FP Green... how is that tur-bro going? (Assuming your car is daily?)
Car sounds fun regardless!
Lol nah when I tell some ppl tht I'm running a low 19psi they almost do backflips "omg my 180 is only running 10psi and I thought I was running high boost" lol lol lol
Haha yeah I know, it can be a shock to some people.
sup motherf**kers.
how many turbros do i need to make 721 kws
has to be 721. not 720 or 722.
If you don't mind lag, use your mother.
If resposne is required, your sister and milk her a lot...
    • Maybe but doubt it, when I jacked it up it was creaking in the j arm again. The inners are all good, I inspected them. Remember that also it did fix the problem but temporarily.
    • Could be the other bushes. The inners.
    • Once you lose the adjustable bushes, you have almost no adjustment at the front for anything that matters. You can only wind so master caster at the front, and ~7° is fine. You won't have choice of front camber. If you only have rear camber arms (ie, do not also have adjustable upper tension arms), you shouldn't change their length very much, because you will introduce bump steer. And, you will struggle to find a workshop that will be capable of doing all the adjustment work necessary to simultaneously achieve a decent rear camber number, get the toe right, and minimise bump steer. I would guess there's probably 8 hours of work there. So, stockish rear camber is fine. Although, keep in mind, that stock camber, by number value, does not mean stock arm length when the car is lowered. You will need to lengthen the RUCA to get back to stockish values and that will require the tension arm to be lengthened a little also. Without any other guidance, any change made to the RUCA should have the 2/3 of the same change made on the tension arm. But that is only a rough rule of thumb and the relationship might not remain linear across a wide range of adjustments. And it might not also be as close to minimum bump steer as you could achieve if you did the bump steer measurement and adjustment properly.
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
