If I gifted you $60k I'd want a damn good present out of it.
Like that 32
I still want to sit in your evo before I get the height things.. I don't know why I'm just sus about them
you are sus... they are seat brackets... they are bits of metal.. they lower the seat 1.5" from its stock position on top of Mt Everest
Give me $60K
Well looks like my car is going to be a write off :(
Going with the assessors tomorrow to confirm
Hardly any compression across all cylinders overheated so much it melted the coilpacks lol
Give me $60K
how are the rear guards... full of rubber?
lol. i honestly think its a good thing toby.
34R come at you.
get your seats and stuff out of it first..
Can't get stuff that is attached to the car, it going to the wreckers unless I buy it back
yeh don't worry Toby now you can get a real car, start preparing for married life
Camry yo!
I will never get a Camry!
Not sure won't be able to inspect till tomorrow
I thought you can if you replace them, ie old seats back in
Hrmm not sure? If that was the case I would put back on the old turbo, injectors etc.. as well lol
did they catch the mofo's yet?
Even with CCTV footage with clear view of the face, I dont think police will bother
this is only really possible in a crash scenario unfortunately..
see how much they want for the wreck :/
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
