Yeh the engine is, everything else seems to fight over what wants to v the weakest link.
But in my case the engine decided to fight as well, spun an awesome bearing
Put it this way, I sold with without an engine.
$10 says you sold it cos it needed an oil change
From this:
To this:
Notbad.jpg. Feels a lot nice to use. Is a bit smaller too so helps with my long lock to lock when parking.
SRS light is on though, cause i turned it on without the airbag to see if it was straight. Now to find out how to reset the srs ecu...
I would assume same as Skyline. Remove earth from battery, pump brake for a little bit so all residual power gets used up, then connect it all up again.
http://www.youtube.com/watch?v=FpWwvWgQ0o4
Came across this board when I was browsing through youtube. Get's a bit repetitive after a while but gave me a couple of laughs. Watch if you're board and have nothing better to do with your life....*sigh*
well if you spun a bearing...you would ahve to change the oil after that..taking the engine out to change oil was probally a little much, and being too lazy to put engine back in as it fell down the back of the couch...
so yeah oil change it is ;)
front lower ball joints cannot be replaced separately, the whole control arm has to be changed. uppers too 500$/control arm?? i dont think so.
Saw the up to the Mario Kart bit and was like wth.... as if they would use Mario Kart and air it until i read the description... lol
Aaron!!!
I got my GoPro3 Aaron edition today! She's such a black beauty!
Know anywhere to buy the suction and pole mounts for cheap?
keep the standard kit on the sedan steve, some 10+15s at the rear and slam it.
i test drove a 6 speed na supra for a mate, was reasonably quick for what it is, but the thing i fell in love with was the gearbox!
Aaron!!!
turn the tables on aaron and steal his ones, bet that nigga wont expect a white boy stealin his shittttt
Dow shift is Asian, Teds usually stocks them, as with Harvey Norman, but I got mine off the site and combined the shipping
And make sure you update it before using it, otherwise it locks and its a pain to reset
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
