yeh, but 230 kw is eeeeeeeasily enough to skid a gtst and you can spend the remaining coin on trackdays/tires etc
and you can tell hwp to smoke your pole if they EPA you....
pretty much what I do now, dat feel is pretty good
(nek minit fined for fog lights) LOL
Edited by UNR33L
Might get intercooler, run a smaller pulley and e85 down the track, however then I need injectors and fuel pump as well which is all $ and don't think the change from 370 to 450 odd would be that different.. would get me dat 10 though best someone has got with a tune only is 11.3 down the 1/4 mile with good tyres
Or perhaps it's time I save for a house :(
Edited by UNR33L
I'm thinking a shed, I need to be able to store at least 4 cars, preferably more!
I'm limited by my sloping block, designing a 6x9 with extra height to stack cars with a hoist, so should fit 3 with storage
lol... do you NEED a 10?
370 is stupid power! why risk blowing an engine on a 50k car for extra power that you wont be able to use?
don't you hate it when you've lost the rear end (more than once) on your FWD when out on a track, later find out the previous owner hit a gutter a few years ago and knocked one of the rear wheels out.
get it measured up at Tyre Factory when they were doing other work and find one of the wheels to have 6mm toe-in and the other 1mm. then take it to Centreline Suspension (more than reputable from what I've seen/read) and they measure 1mm toe-in on both rear wheels........
grrr
My Pulsar also had near on 0mm toe in on one side and 6mm toe in on the other side - as you know that is within Nissan spec and the only way to get it better is to bend the rear beam. It almost always has nothing to do with accident damage - that's how they came out of the factory.
I agree it makes the car very unstable particularly with quick changes of direction. Could best describe it as crabwalking. Noticed it at turns 11 & 12 at Sandown more than anywhere else.
Edited by llama_au
One day I NEED that 10! :P
Edited by UNR33L
ETA for BRZ is now April, oh yeah! Nearly time for nervous butterflies.
That's quick! What happened to 12 month wait? Our 18 month wait for 86 has been upgraded to ~6 months too.
So you can be free?
yes.
Polo TDi...I'm impressed. Averaging 3.4L on the freeway. Could get to Sydney on $60.
yeah that would definitely be my car of choice if i were to go down that path, love the golfs are the GTI much worst?
Golf GTI is a great all rounder daily. Great tuning potential too. For the money though, Polo kicks ass. Turbo diesel moves off the line and the 7 speed DSG helps. Would get one if it was a bit better looking, but compared to others in the same market it's probably the best looking.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
