Vic Wasteland Thread
R31Nismoid
Is that the plate your getting ?
Don't answer my question with a question. I want answer man. NAO!
Also for reference... car is gonna be satin black with chrome meisters with mehbe Gold spokes... might end up with black spokes tho... depends if my mate can come through with powdercoating it gold.
well the plate is ghey (sorry brah :wub:) if it has to be though its black an gold all the way
NB: only if gold on rims otherwise its pointless having gold on the plate
Edited by alr33x
Today's new purchases...
R230 Diff
Nismo RS521 LSD Disc Kit (12kgf/m)
Nissan Diff Side Seals... $5.33 each from Japan, vs $36 each from Brighton Nissan :|
*prays it all arrives and I can get it all together before deca* Single spinning with a shagged diff is no fun...
R230 Diff
PM me price brah
Im thinking of getting one as well
Tell me more about how you managed to fit DOUCHEBAG on a numberplate.
douchebag.
Speaking of number plates, are we able to just replace a single plate with the slimline one?
Just want a slimline for the front.
I think you need to order a pair of slimlines so then have 2 full sets and just rock one of each.
Edit: Oh is that all Grant? I gotta get me one then!
    • Wait, the flappy paddles or sequential is the small penis indicator?  Either way, I can't afford it.
    • You and me both. If I ever get it running again, I'll have to look into cruise control.
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
