"After Installation, test drive the vehicle for about 180miles (300km) at speed less than 40mph (60kmh). Avoid any quick manoeuvres."
Son. Of. A. Bitch! Who wants to come for the slowest cruise in the world with me? :P
what did you install?
So no 300km needed? Figure 8s for 30 minutes and that's it? (Where the fark in the Eastern Suburbs can you do figure 8's in a skyline for 30 minutes without 4 HWP cars and Rapid Response Units showing up?)
Any particular kind of oil for run in and also afterwards?
Figure 8's lyk dis?
i cant see the vid as i'm at work
I just did it in an industrial estate...
used the nismo oil provided with the diff then dumped it an put in motul comp 75w150
Why'd ya leave Coles?
Had enough of it and they refuse to move me to another section.
No point in being unhappy in a job while they're treating me like a pawn.
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
