So the current "thing" is.
pick the diamond for the ring purchase it, and present that.
then she comes in to get the ring made.
that said ti was not what I did, I went with a el chepo ring for proposal, and explained she could pick out her perfect one afterwards...seems to have worked.
This is what I did... simple silver band from tiffany's for the proposal and then we picked one together.
sure beats her wearing the ring she didn't want and hating on you for the next half century!
Just take the one she's wearing. Try and fit it to one of your fingers. Which ever one its closest too, there's your reference
obvious amateure is obvious.... :P
for this to work she has to wear one on her wedding finger, which she wont... because she isn't married
different fingers have different sizes yo
Yo Ham, at Buller last year we were talking tequlias
what were some to try? hitting us USA so going to pick some up
from the airport the selection may be a bit limited... I'd say to go a Patron Anejo and a Herradura Reposardo.
how to get ring finger size of missus....... cut it off while she sleeps?
Download tiffany an co app has a ring sizer in it you just put it on the screen and slide the scale to the circles meet
Failing that ask her friend / family who will keep mouth shut
TOLL priority is f**ked up.
I kinda think they lost my item. Supposed to come on monday, and i was waiting, no doorbell. Found that they left the card. Called them to schedule redelivery to a newsagent, told to go to newsagent yesterday after 10am, it wasn't there. Now they don't know where the f**k my item is.
What can I do? Call ombudsman?
Call Toll and get them to follow it up with the newsagent and call you back once they've located your package... maybe your package is smaller than normal peoples package...
Why does everyone jump straight to ombudsman right away? :P
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
