Bunch of bullies. Beat you both in the twisties :P
Birds; not sure if I could beat golf gti's and R's :(
You under estimate the handling of the FG chassis with coilovers! actually handles pretty decent imo i'd be very surprised if you could loose me through the twisties :P NT05s are awesome tyres too!
Jamie any good pics from the weekend?
Edited by UNR33L
only coilovers? thats cute :P
Come back to me once you rockin bilsteins, swaybars, adjustable camber & adjustable castor!
plus my e-dick is bigger too
started the R up and the rev meter is going f**king crazy... flicks up and down and wont settle anywhere lol.
looks like the excuse i need for the 320km one to go in
Do it.
Nismo 320 > Stock 180
bitch please, aftermarket swaybars ain't gonna save ya :P
what tyres are you on anyways? all of that suspension work is irrelevant with sheit tyres!
Russman had the same setup as my car prior to his rb25 swap and he was running rings around worked gtr's :P
33 Tachs tend to do that, dry solder joints or something?
yeah i read something about dry joints
Do it.
yeah ima buy one tomorrow
perfectrun have them for like $584.75 which is pretty good.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
