Bunch of bullies. Beat you both in the twisties :P
Birds; not sure if I could beat golf gti's and R's :(
You under estimate the handling of the FG chassis with coilovers! actually handles pretty decent imo i'd be very surprised if you could loose me through the twisties :P NT05s are awesome tyres too!
Jamie any good pics from the weekend?
Edited by UNR33L
only coilovers? thats cute :P
Come back to me once you rockin bilsteins, swaybars, adjustable camber & adjustable castor!
plus my e-dick is bigger too
started the R up and the rev meter is going f**king crazy... flicks up and down and wont settle anywhere lol.
looks like the excuse i need for the 320km one to go in
Do it.
Nismo 320 > Stock 180
bitch please, aftermarket swaybars ain't gonna save ya :P
what tyres are you on anyways? all of that suspension work is irrelevant with sheit tyres!
Russman had the same setup as my car prior to his rb25 swap and he was running rings around worked gtr's :P
33 Tachs tend to do that, dry solder joints or something?
yeah i read something about dry joints
Do it.
yeah ima buy one tomorrow
perfectrun have them for like $584.75 which is pretty good.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
