This. You normally upgrade the fuel system capacity when considering an E conversion, which takes care of everything being new...cept the fuel lines (which should be fine as long as they're not crumbling away).
But I has gtr fuel pump :(
Damn it, ethanol tune hey.
Someone tell me how far I can get with 550cc injectors
SO media blasting results:
hmm we need to fit a master cly...lets just hit it with a hammer hard them bog over the dents.
that smooth as rear quater:
quality door:
but when whole rear quaters skins are 56$ it's all fixable...
What brand?
I made it to 330rwkw at 92% duty on nismo 555cc
but most people have run out of flow much lower (thinking nismo 555's are just the 740's painted a different coulour)
Drop am rb26 in an drift on a mountain against some yakuza punk. Do it
lol
you should totally do that man... with the appropriate ethnically diverse group of ambitious 20 somethings it will only take you 1 night including paint!
lol
But then a GTR owner somewhere will be missing his engine...
lol
The best part was ignoring the S15 they could have used instead...
The Mona Lisa if you will...
Also re: the e85 evos, I thought he meant that was happening WITH upgraded 1000cc+ injectors and fuel pump.
Edited by kaitoukid
The only reason the evos pop on e85, is because tuners like to cram timing in downlow.. The rods can't handle to much low end torque..
Burnzy has said out of all the 7's he has tuned on e85 only one popped, because of something completely different.. Ie waste gate or something
glasses are annoying, wake up, can barely see clock / find your phone, have to take them off at the beach / swimming cant look at womens or see mates / throw balls n shit, have to clean them all the time, can't play footy, can't wear sunnies, look like an idiot at 3d movies, can't see shit on roller coasters with no glasses, fog up in shower or heat, can fall off during sex, annoying to get motorbike helmet on, can't take semen to the face, have to get special wider goggles when I was doing motorcross the list goes on, can't motorboat things
Contact Lenses :)
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
