if you dont mind me singing off key, lets do it.
i has bad habit, sing to the highest of my vocal range, then drop 1 octave and continue singing, sounds bad mang.
yeh im serious.. organise it. we come. you sing
i can do that if das what you want.
hahah tuts ma burret.
ahh, sao many drunken fun singing times there. bit more local (to SE anyway) ali baba at glenny is okay, past two times i've gone there. mainly just 2ez to get home! also in city is kbox and fm i suppose. take your pick!
usually deals work out okay $ wise; but protip: smuggle some drinks in ;)
How long was/is the trip?
After a while, you'll realise you want to do it again, I know cos I want to do UK/EU again...
Trip is about 4 weeks total. 2 of them in Vietnam
Next trip will probably be South America or a small trip to Tokyo/Hong Kong pending on time and funds
need new fishing combo.
mainly for trawling from a boat witha little bit of peir work.
thoughts?
http://www.raysoutdoors.com.au/online-store/products/Shimano-Scocorro-662-Spin-Combo.aspx?pid=283680&menuFrom=1021858#Cross
fibre rods are heavy. and a 4000 could be too large even for boat.
just went and took a look at my stuff.
I use a berkeley dropshot, from memory i spent about 80ish on the rod, and a daiwa procaster 2000, hasn't let me down so far. problem though, its an 8 footer. i got it primarily so that i can cast those squid jigs further.
I have a g loomis custom rod, a mate gave me for my birthday, its primarily a boat rod, used to be coupled with a daiwa freams kix 3000, dropped that into the sea off indonesia. but that was an indestructable setup. literally dragged fish up. but cant afford such an exy reel now. unfortunately.
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
