SO car was written off but not put o the register..seems strange.
Repairable Write off...
Cheaper for just car insurance to do a write off payout than fix it (properly).
Thus why this sale is clearly dodgy, there won't be a lot of change from $9,000 o.n.o. if it was fixed properly.
I think it doesn't have to be on the register if the car's over 15 year old?
That could explain why it isn't on the register...
WOOOOOOTTTTT MY CAR IS READY!
Time to go to the panel beaters and pick it up... Need to get there in under 50 minutes or the place will be shut... Waiting on a taxi to arrive now *impatient*
I've already called him saying I'm interested... Waiting on a call back... Will go and see it on my way home if I can.
Called him again just before... I'm going to go see it tomorrow... with Matt...
Shall record the encounter for the wasteland lulz
So... my car had a camry reverse into the middle of the passenger door.
It went into the AAMI assessment center on Tuesday Morning last week (19th)
It was getting a new door, and bring resprayed at a place Monash Car Center on Princess Hwy
I get the phone call that it ready to come pick up tonight.
Went there to go pick it up and it all looked good. the paint colors matched and all was well.
Car was locked, so couldn't open the door.
Accepted the car, drove it home and on the way I noticed a "few" issues.
They've swapped the inner door panel, speakers, glass, etc into the new door. The tint on the glass is scratched quite badly and is peeling (like inch long sections peeling off)
The power mirror does not function at all.
The power window functions intermittently, I'm thinking a wiring connection issue.
The panel gaps are different from the top to the bottom of the door, it varies by more than 2mm from top to bottom.
Letting the door swing shut by itself, it stops with 10cm to go.
Once fully closed, the top of the window looks to be about 1cm lower than it should be, so it doesn't go into the slot where it should go, instead it hits the bottom of the fat rubber bit.
Honestly, how the f**k can a place f**k it up so much... *sigh*
Gonna call JCI tomorrow and rip a new arsehole out of this joint.
2mm panel gap on a 15~ year old car...uhoh lol
Who could even notice 2mm other stuff sounds fair enough though. Panel beaters would have given zero fks they are useless pricks
Edited by alr33x
    • You know the worst thing about acquiring more space for me? I tend to acquire more things to fill the space...
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
