perfect run asking me how much I want to declare the product value on the EMS label of a package they are about to send me..
probably 1.3K-1.5K in parts
getting them to put like 950$ is alright?
200$
'they're all reburbished 2nd hand goods"
Whoh looks great. Good job.
Did the car come factory option with double din? Looks too clean for an aftermarket dash.
Yeah. In japan they came with double din and auto climate control. I managed to get all yhe ducting. Looms. Motors. Sensors. Everything to do the conversion. Very hard to find complete. Hahaha. Very hard to find at all basically
Are you getting them sent with postal insurance?
umm that i cant remember..
im guessing that if i get them to say 950$
it will only be insured for 950 is what your going to tell me?
Yes, to my knowledge. Game of risk. I forget what the barrier for GST and customs duties are.
I was thinking of buying an exhaust off rhdjapan or perfectrun as well and wondering same. Quick research suggested to me;
If goods are over $1000, pay tax on goods+shipping value.
I.e. item $950 + shipping $150 = total $1100, no tax
But item $1050 + shipping $50 = total $1100 PLUS tax (10% GST and maybe 5% some other fee?)
Can anyone confirm?
If you're buying multiple items, get them to send them separately...postage should be about the same cost given it goes by weight. Just more effort for supplier to pack the stuff.
Back in the day we used to mark them as trade sample or gift, which was void of tax and customs duties. Think they might have scrapped it though.
Okay cool :P thanks for all that.
Ill see what they can do.
I'm thinking maybe just getting the 950 insurance and If I need the insurance (which I never really have before) I've got like 3/4 of it covered.
Everything imported/exported needs a value attached, sample or not. Even if it is $0.01.
Middle muffler is a bit over 5.5", it's easily the lowest part. Gonna replace with a resonator and then see how far I can come down.
No more natural camber = wheels lookin pretty Mexican, hope vic roads don't say anything
I took out the centre muffler to avoid a defect for too low. Got EPA'ed instead fml
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
