no you dont, all you need is a thermometer, hot water and an esky ;)
sous-vide almost all my red meat and a lot of other stuff at home, and I dont have a controller
Nah, would be less... even with the capability to have that much power they will provide a detuned engine that can handle any fuel that idiots put in it, and then increase the output by like 5kw with each new model
What kind of temperatures do you need to keep it at? Could you use one of those home brew kits?
no you dont, all you need is a thermometer, a straw, zip tie freezeer bags, hot water and an esky ;)
I sous-vide almost all my red meat and a lot of other stuff at home, and I dont have a controller
http://www.carsguide.com.au/news-and-reviews/car-news/hsv_supercharged_v8_tipped_to_top_w427
I cook most meat at 58c as per MY digital thermometer, and it comes out perfect every time, although my thermometer is pretty mangled as I have dropped it in the sousvide bath about 10 times and into a pot of 175c oil whilst deepfrying...
I usually get my steak from the vic market, leave it in the fridge until dinner and then throw it straight in a HOT griddle pan for like 60 seconds on each side to get some caramelisation on there, then throw it into some ziplock bags, suck out all the air with a straw and lock quickly.
drop it into the esky with the bag jammed in by the lid to hold the meat near the top of the water. set a timer for 45 - 60 mins and go watch tv or cook the other dinner bits
come back an hour later and chuck the bag on the bench to cool a little. and let the protien strands relax
cut the meat against the grain and throw on the plate with whatever sauce and sides I have made.
100% perfect medium rare rump steak that is as tender as all hell... every time
even the 427 would have only been say 300-320rwkw TOPS
I dont think it will be beating leigh's 370rwkw in a hurry, and it will be the TOP model @ $100k +
these are only guesses ofcourse
Also rwkw != manufacturer stated fly kw...
427 cubic inches = 7.0L
Bitch plz I could make 320rwkw with a few little mods to my little 2.5L ;)
mmmm but jelly of dat torque and power band... Super charged dyno graphs are boring... may as well go look at a wall, it's almost as flat.
inb4 leigh invites me to prinny...
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
