2 door is good excuse to watch dem struggle in mini-skirts.
and 2 door is harder to escape while car is moving, you know incase they do a runner.
Good thinking
Keep in mind that Leigh's engine came with a factory 335 flywheel kw and the current HSVs have 325 in stock form. If Holden put out a blown V8 it'll be above the FPV power figure cause that's what those two companies do.
In the end what's gonna matter is displacement and power handling potential...if they use LS9, it's a supercharged 6.2L engine > supercharged 5 litre. Coyote is a great engine, but there's nothing particularly trick about it...all supercharged engines respond well to pulley upgrades and tunes.
It would be interesting to see the price though; if they spread across the range or save it for the GTS.
Gee fair whack on your first outlap.
Looked really slippery? Oil spill there previously?
Aaron. We barely half way through. If u come now. Still tonnes of food!<br /><br />And there is no guinnea cops now!!!!<br /><br />Good wine hurr too. <br /><br />We just doing stuff bit by bit.
Lol mad invite!
Come past one night brahz! Take me for a spin uleh
Pretty sure HSV stated it won't be the LS9, and if it were yeah they're awesome but expect to pay 100k+ for the car lol
Also the ford modular engine is complex, much more than the pushrod single cam chevvy 6.2lts, I'm talking n/a vs n/a here 5lt vs 6.2 and 6.4 ftw
The 5.0 L (4951 cc, 302 cid)[12] "Coyote" V8 is the latest evolution of the Modular engine.[13] Ford engineers needed to design a V8, specifically for the Mustang GT, that would compete with the GM 6.2L LS3 used in the new Chevrolet Camaro, and the new Chrysler 6.4L Hemi ESF in the Charger and Challenger.
Edited by UNR33L
ford and holden both have to keep each-other in check with stock power figures, also the supercar scare shit will return if they go nuts.
Ls9 has displacement and that is all and with 1.2L still isn't as efficient uses more fuel and needs more mods to be on par with a 5.0 on same boost levels.
power handling potential? on stock blower 5.0 coyote many people have made 480-510rwkw stock engine zorst pulley intercooler tune e85 intake.
ls9 will need heads cam, zorst intake pulleys e85 larger heat ex-changer(internal plenum cooler and external radiator)
keep in mind here the 5.0 coyote has a 1.9l blower and the ls9 has a 2.3l
imo stupid debate anyway, FKN v8 MATE
@ hamish, does the sous vide in the esky hold 59 degrees for the entire hour? or is there a temperature drop?
I'd normally prefer to sear after i sv though. so i'd be concerned about temp drop when i put in the meat.
my esky drops approx .5 - 1 deg per hour so not really...
you can sear afterwards, works the same, as you are not putting enough cold meat in to drop the temp of all that water.
I have done both ways, however sealing first works better for sous vide as the flavour of the searing penetrates the meat.
even in professional kitchens with propper vaccuum sealers and circulators I seal the meat first
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
