A45 AMG confirmed @ $74, 900 for September. 6.9-7.1L/100km and the 0-100 dash in 4.6 seconds...
EDIT: The Japanese ad had me convinced anyway...
A-a-ron get me one pls.
Edited by kaitoukid
for the myriad of things you are having done it would be a LOT cheaper to go elsewhere....
im more after a place which can do everything at once - tune + 100k service + install parts
racepace did an awesome job last time i took it there and is much cheaper than another place ive been to a few times, also their previous quotes were pretty low from what i remember..
anywhere you would recommend?
SHEES! where dod you used to have it serviced? Nissan Australia? :P
GT hyper and the Trent to tune...
their quote for my engine conversion was HALF that of racepace... HALF... I have been going there religiously since
ahah i used to go to le mans automotive in templestowe
damn okay half would be a big difference!
might check them out :P
was originally going to see if trent could do the tune
ty
Edited by bluejeans
ask for lin and tell them hamish from SAU sent you.
its a dirtly little shop lol... but they take care of the cars and have done nothing but 100% perfect work on my car every time
Strangely enough, I find the dirty little shops always to be the best ones to go to, and the ones that take most care.
Scott's shed for example, there is shit everywhere. But wouldn't go to anyone else..
I called up Lin once, booked in my car to install the new gear... Injectors, AFM, ECU, Turbo, Fuel pump etc...
Price was good as well, the only problem that he was really bogged down with work in the time span that I needed it to be done, it was going to take 2 weeks to get it done.
So I ended up doing it myself at home over the same timespan, just working a few hours each night... Learnt heaps and somehow didn't screw anything up :D
Wouldn't suggest that route to install all your new fruit on the GTR though, would be very ambitious indeed. (But would save a bucketload for sure)
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
