A45 AMG confirmed @ $74, 900 for September. 6.9-7.1L/100km and the 0-100 dash in 4.6 seconds...
EDIT: The Japanese ad had me convinced anyway...
A-a-ron get me one pls.
Edited by kaitoukid
for the myriad of things you are having done it would be a LOT cheaper to go elsewhere....
im more after a place which can do everything at once - tune + 100k service + install parts
racepace did an awesome job last time i took it there and is much cheaper than another place ive been to a few times, also their previous quotes were pretty low from what i remember..
anywhere you would recommend?
SHEES! where dod you used to have it serviced? Nissan Australia? :P
GT hyper and the Trent to tune...
their quote for my engine conversion was HALF that of racepace... HALF... I have been going there religiously since
ahah i used to go to le mans automotive in templestowe
damn okay half would be a big difference!
might check them out :P
was originally going to see if trent could do the tune
ty
Edited by bluejeans
ask for lin and tell them hamish from SAU sent you.
its a dirtly little shop lol... but they take care of the cars and have done nothing but 100% perfect work on my car every time
Strangely enough, I find the dirty little shops always to be the best ones to go to, and the ones that take most care.
Scott's shed for example, there is shit everywhere. But wouldn't go to anyone else..
I called up Lin once, booked in my car to install the new gear... Injectors, AFM, ECU, Turbo, Fuel pump etc...
Price was good as well, the only problem that he was really bogged down with work in the time span that I needed it to be done, it was going to take 2 weeks to get it done.
So I ended up doing it myself at home over the same timespan, just working a few hours each night... Learnt heaps and somehow didn't screw anything up :D
Wouldn't suggest that route to install all your new fruit on the GTR though, would be very ambitious indeed. (But would save a bucketload for sure)
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
