lol ive thought about it but too scared!
im hoping to do a rebuild at the start of next year and go forged so even if a cylinder (or more was down) will have all supporting mods for when that comes (at worst case!)
so thats pretty much everything - still waiting on hks front pipe and moonface tie rods have been delayed (again) for another month, so waiting for some oem tie rods for the mean time.
  • Like 1
*drools*
Best feeling looking at all the parts you've accumulated before they go into the car....:
what happened with your r33 in the end hamish? did bearing go or just change to evo for new born?
engine 1 spun a bigend... engine 2 (the good one) has gone to that great big street-race in the sky
basically I sold it to some dude that lives in bundaberg, he had it for 3 days and then apparently "backed out of his house into an s15 that was street racing"
then bundaberg flooded
yeah it feels good apart from constantly stopping my doberman from trying to grab parts and run around the house with them :domokun:
ahh see this i didnt know..
so was a write off im guessing?
Edited by bluejeans
Project MU B-Spec Pads?
You should also get a Cusco Brake Master Cylinder Stopper too.
What brand water pump is that?
You should have at least bought Tomei Cam Gears or Racepace can modify your existing ones :laugh:
yeah bspec pads - used them on my gtst and have them on the front of the R - needed some for the rear :P
cusco brake master cylinder stopper is something id like but i guess ill do that when i have some $ to spare lol
its a nissan water pump :P
i was thinking of staying with standard and getting racepace to modify, but dat purpleeee mang!
Ferrets typically have brown, white or mixed fur and are around 51cm in length and weigh around three pounds. Toy poodles are around 25cm tall and weigh around four kilograms.
Dem measurement units
Think I've got brake master sitting in garage somewhere, missing the flat bit thingy (to the master) and it's been painted black - peeling though.
Can look for it if you're keen.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
