i'm armored all the time when i traverse burwood hwy.
can't stab a car. and burwood is still a lot better than coburg.
they could be the kents that entered my garage and stole my fishing bag. though not sure why they would want my fishing bag.
Farkin morons, really worth killig someone over a few dollars?
How stupid do you have to be to hang around the area afterwards.
If Judge Judy has taught me anything, its that stupid people somemtimes do stupid things with some kind of backstory.
Cousins aunties step-brothers mothers dog probably borrowed money a while back, or stepped on someones shoe or called someone a slag.
Anyway point is, if there was some sort of personal involvement or the victim recognised them from kindergarten or if it was some sort of vigilantism (sp) the news/police report isnt going to mention it.
Forced break-in of elderly lady? sure, probably pretty straight forward.
Man stabbed in a supposed mugging and the muggers not taking anything and then being caught within 24 hours? theres probably more to this.
You wouldn't to happen to have all the part numbers for the Neo heater, coolant hoses and thermo stat would ya? :D
Can do, are you gonna be running an aftermarket oil cooler though? If you are it might pay to delete the factory heat exchanger while the engine is out. NA heater hoses clean it up a lot under the plenum and gets rid of a heap of potential leak points.
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
