If Judge Judy has taught me anything, its that stupid people somemtimes do stupid things with some kind of backstory.
Cousins aunties step-brothers mothers dog probably borrowed money a while back, or stepped on someones shoe or called someone a slag.
Anyway point is, if there was some sort of personal involvement or the victim recognised them from kindergarten or if it was some sort of vigilantism (sp) the news/police report isnt going to mention it.
Forced break-in of elderly lady? sure, probably pretty straight forward.
Man stabbed in a supposed mugging and the muggers not taking anything and then being caught within 24 hours? theres probably more to this.
This is a good point...
When a relative of mine was jailed, I couldn't believe how many media reports came out spruiking absolute bullshit - facts and statistics wrong; writing only one side of the story; changing words around to suit; misquoting etc. Completely lost faith in the mainstream media at that point. Focus seems to be on getting the story out there and grabbing attention rather than telling it how it is. Sensationalism defined.
Can do, are you gonna be running an aftermarket oil cooler though? If you are it might pay to delete the factory heat exchanger while the engine is out. NA heater hoses clean it up a lot under the plenum and gets rid of a heap of potential leak points.
So I see, no aftermarket oil cooler yet unfortunately :(
Where did you get that pic from? One of your jobs? Looks very less cluttered than my stock one
@@Birds
when we had a shooting near the club, the herald sun ran a FRONT PAGE article saying the shooting happened inside Hard Kandy. They included our name, logo, a photo of people on the dancefloor and a floor plan of the clubthat was complete with little stars showing where shots were fired and where the fight broke out.
the shooting was unrelated to HK and actually happened at the exford which is on the other side of the road and has nothing to du with HK. It also happened over 30 minutes after we kicked the group out of our club for being overly drunk and abusive.
still the herald sun just made up a headline grabbing story and there was nothing we could do as once the paper was run, the damage was done.
we contacted our lawyers (a HUGE international firm) and were told that there is no point pursuing it as the herald sun make a habit of doing this and has the means and finances to defend the issue for a lot longer than we do
cliffs notes: herald sun has no integrity and I would like release a pack of ebola monkeys into the building and lock the doors / windows
Here's the part #'s for R34 heater hoses, rad hoses, thermostat & heater core.
Upper Rad Hose - 21501-AA000
Lower Rad Hose - 21503-AA000
Heater Hose Core Upper - 92401-AA000
Heater Hose Core Lower - 92410-AA000
Metal heater hose piece on firewall - 92403-AA000
Heater hose upper - 92400-AA500
Heater hose lower - 92412-AA500
All The Hoses for the heat exchanger
14056-21U20
14053-21U10
14056-21U10
21307-21U20
21307-21U15
Thermostat - 21200-V7205
Heater Core assembly - 27140-15U00
If you have the opportunity to do an aftermarket oil cooler it would save a bunch of effort and be better for your engine in the long run, These are the parts needed for heat exchanger delete which then get rid of the upper and lower heater hoses and all the heat exchanger hoses as well.
Fitting between pressure sender and block - 25071-F6000
Front Heater hose - 92412-70T00
Rear heater hose - 92400-70T00
Threaded piece for oil filter - 15213-21001
Block fitting for Rear heater hose - 14075-75T00
@@Birds
All of them have no integrity as far as I'm concerned. The moment something becomes more about ratings and money than truth, corruption has a path. There's more to everything, which is why we're never in a good position to judge based on news alone. Even experts disagree!
A friend of mine did work experience and confirmed what we already knew: working for the herals sun requires selling your soul.
And unfortunately, I work with people who read the shit. I do know poeple who read it, just so they can point out all the errors and how misleading the stories are, which is almost just as bad.
Offloading responsibility onto others is quite possibly the best way to get through life without a hitch. I believe they teach courses on it, but they call it a diploma of management.
    • Oh, yeah, look - here's the thing. You always replace the tensioner when you're going in there to replace a belt....under normal circumstances. You want to make sure it is good and safe, and that you don't create a reason to take the front of the bloody motor apart again. But in this case, OP is replacing a belt that has aged out on time, not usage. The belt is a million miles away from aging out on usage. The belt gets a time "limit" merely because it is made of rubber and can degrade naturally. The tensioner? Not so much. I reckon it could last forever on the current usage pattern. So I reckon if the thing is going to continue to get used at the same rate, replacing the tensioner is somewhat gratuitous. Would I replace it if I was doing it on my car right now? Hell yes. Because my car does 10-20 thousand kays a year. So it's all going to be the same thrashedness. Would I YOLO it on OP's car. More than likely.
    • I dunno. I think any one of those from each side to sump is probably enough. Remember - this is about creating a path for gas flow up from the sump to the cam covers. That gas flow then has to leave via the lines to the catch can. There's probably little point in providing 100% more capacity from sump up to covers cf. what you have from there to the catch can. Put in the 3 convenient ones? Any which way that you see fit. That'd be my thoughts.
    • Getting holes drilled into to cam covers and AN10 fitting welded on. My sump has 2x AN10 fittings on it already. These are the options I have come up with that can be done without needing to remove the sump to add more fittings. In all options front of passenger side cover connects to VCT head drain bung (i know this isn't the best spot but my feeling is it must do something). Option 1 (pink). The back of each cam covers gets its own line to sump. Option 2 (blue). The back of each cam covers are linked and share a line to sump. The front of drivers side gets its own line. Option 3 (Black). Drivers side are Tee'd together and share a line to the sump. Passenger side rear gets its one line to the sump.
    • I'd be surprised if Nissan doesn't mention it in the manual as it seems unlikely that a tensioner is going to last 200,000km.
    • Tapin,    So got mine up and realize a few things. First was my slave line doesn’t reach the other side, so I have to get a longer hose made. I want to ask did you have to extend your wires for the CD009 sensors? One on the driver side(right side of car looking at the car from the rear) and one on the passenger side( the left side of car from rear). And do you know what those two sensors are respectively? I know it’s not Speedo since we talked on this already. And I may have to separate the trans again to swap out throw out bearing. We will see. Did you run your RB slave cylinder? I know you cracked your original but replaced it with a nismo. But wasn’t sure if you bought the one designed for the CD009 or not. Thanks
