When i WOT from 1-2 or 3-4 the car misfires when changed into the higher gear for a moment and then takes off. Anyone have any ideas to what the issue could be? Is it a tuning issue? Or could it do with heat range of spark plugs?
Car pulls through the revs just misfires on start of new gear and clears up. Dont think its coilpacks as they would degrade higher in the rev range...
Cheers
Cheers
Time for new car.
f**k, had to stop reading that thread after page one. The jimmies...they were starting to rustle.
Haha
I have also been through this
Talking on the phone with gf for 3 hours. It's 1:00 AM
Me: Ok, I guess it's time for me to go to bed. It was great talking to you
Her: Why do you want to hang up?
Me: Well, it's 1:00 in the morning and I have work tomorrow.
Her: Do you just want to get rid of me?
Me: No, I've been talking to you for 3 hours
Her: Oh, is that too long for you to talk to your gf?
Me: No, I like talking to you
Her: Then why do you want to hang up now?
Me: Because I am tired and it's time to go to sleep
Her: I hate you sometimes
Me: Why?
Her: Because you don't really like me. You probably want to date someone else
Me: I just want to go to sleep. I'll call you on my way to work in the morning.
Her: YOU ARE JERK! Why can't you call me right when you get up?
Me: Well, I would prefer to get ready and call you while I am driving
Her: You don't care about me! Are you cheating on me?
Me: No! Why would I do that
Her: Because you are trying to get rid of me! You don't want to talk to me anymore!
Me: I'm tired. I need to sleep or I will be a zombie at work tomorrow
Her: Oh, what is more important? Me or your work!
Me: It isn't about that. I have to go to work in the morning and I need to do well
Her: If I was the most important thing in your life, you wouldn't care about your job!
Me: If I lose my job, then I won't be able to take you nice places anymore
Her: Fine, go ahead and hang up. I HATE YOU! BYE
lol add "By the way...I'm cheating on you...and it's all your fault." to the end of that conversation and you'll have the ultimate irrational female thought process. Irrational behaviour or logic like that often involves some sort of lying or cheating cover up. Where there's smoke, there's fire!
P.S. a similar one goes like this:
Boy: You hang up first
Girl: No, you hang up first
Boy: Alright! *hangs up*
Next conversation...
Girl: You hung up on me...don't you want to talk to me anymore?
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
