You bought a lot of your gear from Perfectrun didn't you Anthony?
Postage costs on there seem a bit higher than nengun so hoping stuff arrives nice and quickly
yeah man I found most parts to be cheaper than nengun, and everything arrived pretty quick.
well all except for 1 part which has been on back order and still is now..
to be honest i bought nothing from nengun as perfectrun and rhdjapan prices always worked out better for me.
i think it varies alot..
what did you buy?
alvin: "i only have my cat, to keep me company through the cold winter nights"
nek minnit:
if a nekomimi girl will join me in my room, of course i'd be happy, but nope.
Your life sounds scarily like mine Alvin...
girlfriend's in brisbane. =(
what did you buy?
Just pads at this stage, might spend a bit more if the yen nose dives further lol
Ah all good!
I've used nengun before and postage hasn't been too bad.
Can't get f**king r33 rear strut bar off - all the bolts are so f**king tight
*waits patiently for page 1997 to mention goldeneye*<br /><br />almost lost control of the hilux in the wet this morning. people probably thought i was trying to drift. the shitty tyres, low rpm/high torque and the weight shift means difficult to handle. want to flag the tyres as a safety issue but the specs meet toyotas manual, so the fleet can buy whatever tyres that fit (even though these ones have terrible water-flow tread)
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
