You bought a lot of your gear from Perfectrun didn't you Anthony?
Postage costs on there seem a bit higher than nengun so hoping stuff arrives nice and quickly
yeah man I found most parts to be cheaper than nengun, and everything arrived pretty quick.
well all except for 1 part which has been on back order and still is now..
to be honest i bought nothing from nengun as perfectrun and rhdjapan prices always worked out better for me.
i think it varies alot..
what did you buy?
alvin: "i only have my cat, to keep me company through the cold winter nights"
nek minnit:
if a nekomimi girl will join me in my room, of course i'd be happy, but nope.
Your life sounds scarily like mine Alvin...
girlfriend's in brisbane. =(
what did you buy?
Just pads at this stage, might spend a bit more if the yen nose dives further lol
Ah all good!
I've used nengun before and postage hasn't been too bad.
Can't get f**king r33 rear strut bar off - all the bolts are so f**king tight
*waits patiently for page 1997 to mention goldeneye*<br /><br />almost lost control of the hilux in the wet this morning. people probably thought i was trying to drift. the shitty tyres, low rpm/high torque and the weight shift means difficult to handle. want to flag the tyres as a safety issue but the specs meet toyotas manual, so the fleet can buy whatever tyres that fit (even though these ones have terrible water-flow tread)
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
