Call them up, ask to come around to talk to them about some things... or make some other excuse to go around there...
Parents know that boyfriends don't normally do that sort of thing out of the blue, so they'll know whats up... If you know that they know what's up, it'll be easier...
My sisters husband invited my dad out to play a round of golf and asked him about half way through the back 9... he was trying to think of a way to ask for like 6 holes... Needless to say his game was absolutely horrible up until that point ;)
Yeh I agree with the tradition / respect side of it still intimidating we get along but when the day comes ill be packin bricks for sure
Hypothetically
What would you do if he said no?
Not that his going to, its not like your a bum on centrelink
Yeh people ask that but it seems so unfathomable I haven't given it a thought probably be stunned for a minute and ask if its a joke then move on all the same? dunno I know a dude who got told no twice lol
Dezz, loled @ that pic you got tagged in on facebook, looks like you guys were preppin that kids angus getting tackled.
I wouldn't mind getting back into footy, I've got good ball skills *nohomo* however think now over 18s would demolish me, I'm like 72kg 5"9.. see some of the people playing at the oval behind my house and they're f**king huge
Alex, your mrs is Italian. You've got no choice lol
Personally, I'd speak to the parents, but more so to inform them that I'm taking their daughter off their hands. If they're going to say no, they would have done it when we were dating
Fellow brahs who have dusted off the knee cap im curious to know so share your experience did you ask the in laws first or not? If so How awkward was it? How'd ya go about it?
I didn't as I knew her mum could not keep it a secret..
that said she had been asking when are we getting engaged for nearly 2 years so I knew her feelings on it.
thinking about it it's kinda sexist as well.
unless your going to ask your folks as well if they give their blessing..then she can be the last person in melb to know it happening.
I was about to save his life
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
    • Potentially some interesting data for some of you here; Hank Iroz from Iroz Motorsport testing a new Xona Rotor 5964S on a Audi RS3 2.5L DAZA motor. https://facebook.com/share/p/14EU18MyDqZ/ Cliff Notes: Turbo has the new Xona XRE compressor aero with an X4C compressor cover, reportedly 0.64 rear housing. 900whp (670kw) @ 37psi, 170k shaft speed, motor is making 2bar (29psi) boost by roughly 3800rpm, 500lbft (670nm) torque by 3500rpm. They overlaid a stock RS3 on USA 91 fuel (red), and a "Stage 2" RS3 on E85 (yellow), and this 5964S (blue) - the 5964S isn't losing any ground to either. Apparently out-flowing their prior tests with a Xona 8264S (green), and this 5964S (white) also has a smaller A/R than that did.
