Vic Wasteland Thread
R31Nismoid
As above...unless you're having troubles, go as low heat range as possible...6 is good for that power.
im running bcpr6es-11's at the moment but trying to suss out if its still correct for the increase in power and boost.
Getting a bit of misfire after some spirited driving and seeing if i can fix it up with some colder sparkplugs...
NGK site says:
Ignition Timing
  • Advancing ignition timing by 10° will cause the spark plug tip temperature to increase by approximately 70° to 100°C.
  • A colder heat range spark plug may be necessary if the ignition timing has been advanced to near the knock level. Higher cylinder temperatures near the knock level will bring the spark plug firing end temperature closer to the pre-ignition range.
Forced Induction (Turbocharging, Supercharging)
  • A colder heat range spark plug may be necessary due to the increased cylinder temperature as boost pressure (manifold pressure) and subsequent cylinder pressure and temperature increase.
props only given if you know what a j19lm goes in
pretty sure they go in a VW golf 2.0 TDi..
either that or something you mod to power your barstool
Well came away to Hepburn springs got a nice villa dinner with candles and all that surprise cake and then got her to close her eyes and justed dusted off the knee
    • HOTGTR r35 - down next to indro shopping mall
    • For sale is my 2002 VX SS LS1 Commodore  $30,000 ono 160k km Located at Holsworthy 2173, NSW Extremely clean car and well maintained  I have receipts for all work done, and I've had alot of work done, and more money spent than I care to remember on the build Car makes around 500hp at 7 psi Harrop 2300 supercharger with FI induction interchiller installed and tuned by Autotech Engineering  Mild cams, and PAC valve springs Automatic 4l60e transmission was built by Craig's Automatics  Harrop Truetrac LSD with 3.46 gears  Ceramic coated 4: headers, 4" exhaust with Varex rear box RaceTCS traction control Engine serviced every 5k km, transmission serviced yearly, diff serviced every 10k km Some spares and parts will be included  There's lots of other stuff done over the years I've owned it, like new brakes, coilovers, starter motor, sound proofing, head unit with reverse camera, alarm, just check out the "Bogan Cruise Ship" build thread for everything that has been done and specs of parts used, apologies for all the other random stuff in the build thread, there's a few cars, and a bike in there, but, if you scroll past the non relevant stuff there's all the work done Car is currently stored undercover at my work, you will need to have a current driver's licence to get signed onto site to view the car as it is a secured site and I will need to sign you in through security  Any test drives will be within this site I'll post up more pictures next week after I service it and detail the car 20231108_170005.mp4.7b8746d1a41f6d4a6fe0b64232f506ab.mp4   No I don't want to swap it for anything If your serious about looking for one of these, check out the others available, then come look at this, then we can negotiate  PM me for further details and timings
    • Cold start, battery is one I got with the car and dead! Jumping is required as it won’t hold charge and yes the alt is working  IMG_8373.mov
    • Just another step forward. Neary time to put front end back together after I get this box sorted. Shortly
    • For what it's worth (I'd never looked at the button closely enough to work out it has a person on it!) with the switch 'active' double-pressing the unlock on the remote will cause lights to turn on. As I recall it will cycle through plain-unlock, unlock-with-park-lights and unlock-with-headlights as you repeatedly double-press unlock.
