DiMattinas is decent on Lygon St.
Cheers for the invite but tired of being third wheel
/dat single life with couple friends ~_~
Kebabs only eaten after midnight. Fact.
Have misfire at high rpm.
Looks to happen after long drive. (Wasn't showing signs at dyno day)
Obviously misfire occurred after tune.
Currently have splitfires, new coilpack loom & optima yellow top.
Running bcpr6es-11 (11mm gap)
Booked in for a review with Trent on Wednesday. Could my issue be spark plug choice (wrong heat range or gap) or a tune issue?
Not sure if I should change plugs prior to trents...
Awesome sticker
relevant to my interests
http://www.ebay.com.au/itm/I-LOVE-HEART-MY-R33-STICKER-DECAL-4-NISSAN-SKYLINE-JDM-DRIFT-RB26-GTR-GTS-GT-/200817373922?pt=AU_Car_Parts_Accessories&hash=item2ec1a5f2e2
that guy also has i heart fg/bf/ve/s chassis/r chassis/subie/honduh/rx.
If anyone can point me towards somewhere i can get a large vinyl wall sticker of a r33 i'll give you all of my internets
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
