Vic Wasteland Thread
R31Nismoid
So replaced my BCPR6E-11 with BCPR7ES-11
Misfire is gone when pulling through rev-range! Someone explain! Was going to regap them if misfire occured but its all clear...
i like power :)
Couple possibilities:
-Existing spark plugs were fked and replacing for the same could have cleared the misfire too
-Higher heat range is actually working for you
-A coilpack was loose / not seated properly and removing/replacing them to replace the spark plugs seated them properly
-You're in the matrix and they want you to believe the misfire is gone. You think that's air you're combusting?
Leg faggots: do squats, then leg press to finish them off, then hamstring curls, then calf raises. You need not do more than this.
whos going to the nats this year? in adelaide... not too far from the city. should be a great one, mainly because it isnt in the fkn bush this time
birdman, alvin. we missed you niggas
I'm going to regret saying this
But I'll be there
No fin idea how ugly the car will be as wont have time to fix rear guard
But planning to smash up std red again just for shits and giggles
Car will be Frankenstein dents multi colours but meh race car
I might be keen to go this year
Haha definitely the matrix
i'll be graduating this year, so i might be there, but still up in the air mang.
i'll be there if i can find a jerb. get my TR/PR application approved and shit.
Got ARTZ to give the Birdsmobile a polish, then followed up with my trademark waxing skills. Ran out of daylight for pics :(
Should have taken some before piccies too! That bootlid used to be scratched/swirled to the shit and there used to be fuel/exhaust crap all over the rear bar.
looks good, am jelly! fckn black cars. black is right at the bottom of my list of colours on next car... although it can look so amazing when clean.
i need a cut polish too :'(
Black is impossible to keep clean and look good :(
Get ARTZ to do it, he's good and cheap!
pm me deets pls? :)
i had a black car before, never again.
yes, yes, and yes. clean for 0.2 seconds :'(
    • HOTGTR r35 - down next to indro shopping mall
    • For sale is my 2002 VX SS LS1 Commodore  $30,000 ono 160k km Located at Holsworthy 2173, NSW Extremely clean car and well maintained  I have receipts for all work done, and I've had alot of work done, and more money spent than I care to remember on the build Car makes around 500hp at 7 psi Harrop 2300 supercharger with FI induction interchiller installed and tuned by Autotech Engineering  Mild cams, and PAC valve springs Automatic 4l60e transmission was built by Craig's Automatics  Harrop Truetrac LSD with 3.46 gears  Ceramic coated 4: headers, 4" exhaust with Varex rear box RaceTCS traction control Engine serviced every 5k km, transmission serviced yearly, diff serviced every 10k km Some spares and parts will be included  There's lots of other stuff done over the years I've owned it, like new brakes, coilovers, starter motor, sound proofing, head unit with reverse camera, alarm, just check out the "Bogan Cruise Ship" build thread for everything that has been done and specs of parts used, apologies for all the other random stuff in the build thread, there's a few cars, and a bike in there, but, if you scroll past the non relevant stuff there's all the work done Car is currently stored undercover at my work, you will need to have a current driver's licence to get signed onto site to view the car as it is a secured site and I will need to sign you in through security  Any test drives will be within this site I'll post up more pictures next week after I service it and detail the car 20231108_170005.mp4.7b8746d1a41f6d4a6fe0b64232f506ab.mp4   No I don't want to swap it for anything If your serious about looking for one of these, check out the others available, then come look at this, then we can negotiate  PM me for further details and timings
    • Cold start, battery is one I got with the car and dead! Jumping is required as it won’t hold charge and yes the alt is working  IMG_8373.mov
    • Just another step forward. Neary time to put front end back together after I get this box sorted. Shortly
    • For what it's worth (I'd never looked at the button closely enough to work out it has a person on it!) with the switch 'active' double-pressing the unlock on the remote will cause lights to turn on. As I recall it will cycle through plain-unlock, unlock-with-park-lights and unlock-with-headlights as you repeatedly double-press unlock.
