Vic Wasteland Thread
R31Nismoid
^^ pm Artz. I'm sure he will appreciate the PM.
Btw where the f**k is he?
You coming cruising on Saturday? Heading to certified, then down to Arthur's seat...
unfortunately i'm actually doing something. assignments, they're all due tomorrow! =(
know that feel, brah :(
certified is THIS sat? x____x
and cheers pm'd ARTZ, will see what happens :P
but Clarkson said it was no good
i lol'd
But less gap means less power :(
Bcpr7es-8?
yes, but check the gap befiore you put them in.
Lol and as Leigh's picture. Less gap, more fun
this!
Awesome thanks for the /skylinesaustralia discussion in the wasteland.
Thinking of buying bcpr7es-11 to see if misfire caused by heat range of plug. If issue still occurs, I'll drop them to 8mm?
Thoughts on this? Cheers
just gap to 0.8
So replaced my BCPR6E-11 with BCPR7ES-11
Misfire is gone when pulling through rev-range! Someone explain! Was going to regap them if misfire occured but its all clear...
i like power :)
just run them at 0.8... it's what everyone does and has always in RB's for a reason.
Your 1.1 is factory reccomended for factory setup running factory power.
You have gone and changed a bunch of things inc tune...
All the 1.1 will do is increase the chance of the miss coming back later on.
dont be a flog and run 1.1 because the manual says so, if that's your jive go crack a Dr Pepper, hang out with the NSDOC boys and circle jerk over your original owners manuals.
0.8 has been proven time and time again to be the only gap to run in modified RB's.
i lol'd
this!
just gap to 0.8
Haha good ol NSDOC. Point taken, will regap to 0.8mm. Thanks :)
    • HOTGTR r35 - down next to indro shopping mall
    • For sale is my 2002 VX SS LS1 Commodore  $30,000 ono 160k km Located at Holsworthy 2173, NSW Extremely clean car and well maintained  I have receipts for all work done, and I've had alot of work done, and more money spent than I care to remember on the build Car makes around 500hp at 7 psi Harrop 2300 supercharger with FI induction interchiller installed and tuned by Autotech Engineering  Mild cams, and PAC valve springs Automatic 4l60e transmission was built by Craig's Automatics  Harrop Truetrac LSD with 3.46 gears  Ceramic coated 4: headers, 4" exhaust with Varex rear box RaceTCS traction control Engine serviced every 5k km, transmission serviced yearly, diff serviced every 10k km Some spares and parts will be included  There's lots of other stuff done over the years I've owned it, like new brakes, coilovers, starter motor, sound proofing, head unit with reverse camera, alarm, just check out the "Bogan Cruise Ship" build thread for everything that has been done and specs of parts used, apologies for all the other random stuff in the build thread, there's a few cars, and a bike in there, but, if you scroll past the non relevant stuff there's all the work done Car is currently stored undercover at my work, you will need to have a current driver's licence to get signed onto site to view the car as it is a secured site and I will need to sign you in through security  Any test drives will be within this site I'll post up more pictures next week after I service it and detail the car 20231108_170005.mp4.7b8746d1a41f6d4a6fe0b64232f506ab.mp4   No I don't want to swap it for anything If your serious about looking for one of these, check out the others available, then come look at this, then we can negotiate  PM me for further details and timings
    • Cold start, battery is one I got with the car and dead! Jumping is required as it won’t hold charge and yes the alt is working  IMG_8373.mov
    • Just another step forward. Neary time to put front end back together after I get this box sorted. Shortly
    • For what it's worth (I'd never looked at the button closely enough to work out it has a person on it!) with the switch 'active' double-pressing the unlock on the remote will cause lights to turn on. As I recall it will cycle through plain-unlock, unlock-with-park-lights and unlock-with-headlights as you repeatedly double-press unlock.
