yeah man pretty good value considering it comes with everything! I'll have a think about it
What's the stock setup at the moment on your Ford?
How do they hold up with the power at the moment?
Weekly wash and a 6 monthly detail from final inspection :P
well worth the effort too...saw your car at dyno day it was clean as a :whistling:
I do clay and wax every 6 months...other than that just wash it whenever..coz too busy washing other peoples cars to do my own..
my skyline looks like balls :laugh:
322mm rotors, not sure about the caliper but pretty sure the SS runs the same.
quote from a review actually:
Braking: With the same brakes as the XR8 (322mm and 302mm discs, sliding calipers), the 315kW GS is under-braked in our view, even as an entry model.
Feel through the pedal is soft, making it poorly matched to the ability of the engine. A shame, then, that the GT's four-piston Brembos are no longer an option on the GS.
I mean they're fine for the street really.. it's probably more if I want to do some track stuff
Bonus is also 6pot brembos look badass :P
But yeah bit of a shame you couldn't get the GS with brembos it does feel like it's missing them.
Edited by UNR33L
you mean weight...
Who is good for mech work? Is sabaddin the only (non-Racepace) club supporter?
GT Hyper, tell 'em hamish sent ya
usually frankston people are only one of those things...
oi!! i heard that kunt...man I cut and polish the crap outta your car twice and nobody even notices a difference..spend half an afternoon on birds car, give it one quick buff and its noticably better ...
I hate white cars....:rant:
Used to pack a spray bottle of waterless wash and clean microfibre cloths, wash weekly, wax monthly, and clay every 6 monthly. After 3 years, it only got washed in the summer and then only if I had a meet or I was going out.
Yeah right!
I mean, you could get away with running a top quality set of front brake pads and slotted rotors with the stock setup.
But if you are finding you need more stopping power, this Brembo kit for $2K seems the best way to go for a street package...
Yet you are also track ready.
you mean weight...
:rofl:
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
