yeah ARTZ, I was there. Were you with Scott on the cruise?
hmmmm..... oxidation, how to get rid of it?
yea that was me... :D
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=419386
this is you yeah!! ^^
OK so some-one educate me here.
Bought a new battery for Katies Mazda 3 today.
Went with a basic Champion HD.
as I was putting it in I noticed the little advertising tags on top, as you do.
they claim, their batteries increase your fuel economy by 2%.. now considering I did a basic lift both and the new one is heavier than the OEM one it cannot be due to less weight.
SO how the feck does a battery improve fuel economy by anything???
If you teach me how to use it :P
lol..
get this
http://shop.finalinspection.com.au/product_info.php/cPath/39/products_id/141
some of this
http://shop.finalinspection.com.au/product_info.php/cPath/27/products_id/133
watch some utube tutorials, find old car, (not yours) wash it, clay it and start buffing...after about 20 cars you should know what you are doing..
can I have a go now? .. :D
my assumption is that it's to do with drawing less power to charge it
I thought about that.
But as far as I'm aware alternators run at a set speed not variable as per current load? that said I could be be very wrong. and thus asking advise.
I just think it a bad marketing plot and suckering ppl in.
if people are being sucked in... then it's not bad marketing ;)
Sexy driver is all I can think of when looking at that photo.... ;)
Sounds like their bad marketing plot suckered you into buying it Martin. :P
By making you believe so.
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
    • I'm late to the party. Been busy with a newborn... Keeping me up at all hours of the night.  I'll look into purchasing ID 1750's then! Thanks everyone for the concrete evidence.
