GTR Shafts don't fit in GTST hubs.
The Drive shafts on my car (A-LSD GTST) were 30mm splined 5 bolt shafts
The new Diff has 6 bolt half shafts, so I decided to use the GTR Shafts that I got with the diff, but then discovered that GTR Shafts have 32mm splines.
So I pinched the 32GTR Hubs from Matt Borci's 32R rolling shell and swapped them into my knuckles...
Like a glove... ? Definite learning experience :P Now I just need to get my ABS working again and I'll be very happy :)
Whats the must have accessory for the gopro3? LCD screen or battery pack? Or neither.
what you want to use it for.
if your need long life the battery pack is good.
LCD is useless for the 3, just use the app and use your phone as view finder.
spend extra money on attachments and mounts and such.
LCD is a godsend for the GoPro 1.
never fit on the GoPro 1 HD2 had the expansion port, I've now got the wifi backpac for it and that better than the LCD as you can control it from in the car with it.
3 has it built in so even better
Happy birthday birds!
Fark celebrity apprentice hasn't started and yet I despise it already not to mention the lack of celebrities - dawn Fraser sure the rest have about as much profile as roadkill
i was thinking the same thing, at least the u.s version is alright.
I have the HD hero and it fits; pretty sure it's a GoPro 1
    • The nissan manual says to change coolant every 2 years. Is this still necessary if you're using coolant like Penrite or nulon which has improved over the years? It says it lasts 500,000km which seems hard to believe lol.
    • According to the Muse website, totally different material. The originals were that horrible solid foam rubber that was used for a lot of rear spoiler/flap things, like on Mitsu Galan GSRs. Heavy, and with enough compressibility/flex that any paint on them would crack fairly quickly. The Muse ones are just ABS, which is obviously similar to GTR lower front lip, etc etc. ABS is a good choice if you have the ability to tool up for it. The only thing better might be TPU-RIM or something equivalent. The TPUs were good. Plenty of flexibility (in twisting, bending, etc) but not really in compression.
    • Update 24/01/2025:    Bought a GReddy/Trust Intercooler (crossflow spec-LS) that was meant for a R33 GTST $871 AUD shipped, and a GReddy Profec boost controller $483 AUD, both brand new from Japan. Being honest, I would've thought the intercooler kit was discontinued but I guess not yet. Decided due to funds + time, I'll stick with a nistune on this stock-ish setup ( stock turbo set to probably 10-12psi ) and have it run cleaner ( suspect the 3" turbo back etc has sh*tted on my economy ) for my trip down south soon for the WSBK. Hopefully I can get it all installed and tuned by then. As for who I am getting it tuned with, I will be going with Toshi, (not hearing back from DVS so scratch that). There is also Birrong Auto but not sure if they do nistune installations and if they even tune it... Otherwise, anyone know where I can get my hands on an aluminium intake/suction pipe for an RB25DET NEO?
    • The german cars I've worked on seem to have that issue(in more than just headlights). Mostly where hot, but also just the insulation hardening and cracking in various places. Not abnormal from what ive seen.
    • According to the Muse website, similar material, but not the same. Meant to help with stopping the paint cracking. In saying that, I had genuine ones on my last grt, and never had that problem.   Could you post pics when you get them? Very much thinking of buying the Muse ones over fibreglass.
