GTR Shafts don't fit in GTST hubs.
The Drive shafts on my car (A-LSD GTST) were 30mm splined 5 bolt shafts
The new Diff has 6 bolt half shafts, so I decided to use the GTR Shafts that I got with the diff, but then discovered that GTR Shafts have 32mm splines.
So I pinched the 32GTR Hubs from Matt Borci's 32R rolling shell and swapped them into my knuckles...
Like a glove... ? Definite learning experience :P Now I just need to get my ABS working again and I'll be very happy :)
Whats the must have accessory for the gopro3? LCD screen or battery pack? Or neither.
what you want to use it for.
if your need long life the battery pack is good.
LCD is useless for the 3, just use the app and use your phone as view finder.
spend extra money on attachments and mounts and such.
LCD is a godsend for the GoPro 1.
never fit on the GoPro 1 HD2 had the expansion port, I've now got the wifi backpac for it and that better than the LCD as you can control it from in the car with it.
3 has it built in so even better
Happy birthday birds!
Fark celebrity apprentice hasn't started and yet I despise it already not to mention the lack of celebrities - dawn Fraser sure the rest have about as much profile as roadkill
i was thinking the same thing, at least the u.s version is alright.
I have the HD hero and it fits; pretty sure it's a GoPro 1
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
