I have the HD hero and it fits; pretty sure it's a GoPro 1
ok looked it up
so the first of the gopro as we know it was acautlly the gopro Hero 5, SD ran on AAA batteries and 2gig card only,
This was my first one so guess that why I call it the first gen,
then the Hero 960 a higher res version
then they dropped the numbers and started calling them.
HeroHD,
HeroHD2
HeroHD3
go figure.
My R33 GTRST made it to work this morning :D It's around the corner getting an alignment as we speak.
Now, who can remember the Bedding in instructions for a newly rebuilt 1.5way with Nismo discs... Hamish?
I need to go and do 30 minutes of slow figure 8's in an empty carpark somewhere that police aren't going to show up and defect me for "doing hektic skids"... This will flatten and bed in the plates in the lsd center by moving/grinding them back and forth against each other.
Keep speeds down (like try to stay under 60 or so) for the next 1000km? This one is going to be tricky since its a daily (but I can take mainly 60 zones to get to work and back)
Not bad job...
Pretty happy. Roof bonnet boot was all white and faded from oxidation.
Yet to see car in sunlight
nice...that red always does that...its a shocker...but gives good results when polished up :thumbsup:
so what machine did you buy ?
This is the car that killed my buff the other day...time for a new one...
<br />nice...that red always does that...its a shocker...but gives good results when polished up :thumbsup:<br />so what machine did you buy ?<br /><br />This is the car that killed my buff the other day...time for a new one...<br />
Bought das6 pro. Man this shit takes a lot longer than a rotary. At work I could have finished this car in 3 hours. <br /><br />Took 9 hours instead. But it was a single stage paint and layer was fairly thin. So I didnt want to take off too much paint. So no heavy cutter. Gave it a nice coat with 22ple as well. <br /><br />Whatd u do to the 300c? Like stage wise. Did it have a ceramic clear coat?<br />
Yep, this part I've got down pat...
What I'm wondering about is how crucial is the low speeds and how many km before I switch out the oil for the first time. Considering I'm using a "used" crown wheel, is the low speed stuff mainly to protect that if it was brand new?
Or would higher speeds affect the new LSD Center as well...
think of it like bedding in brakes... I did this for 30 mins straight away then binned the oil and used motul comp 75w150
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
    • These look like S13 wheels.  And Welcome!
