first car was my dads old N13, mum had an N16, sister bought an N14. Test drove a couple of cars and an N15 SSS was easily the best and cheapest. The interwebz showed me what could be done with them and how to enjoy it, then I bought a heavily modified one and continued to alter.
it's not an addiction... it's not like you continue to buy parts even if you can't afford it. unless you have track days or cruises planned and deadlines to meet. but at the end of the day, a car build has all the time in the world really.
Yeah I sent PM Dezz, sorry should of warned you...
I dunno about you guys but when I started modifying my car I was definitely hooked and spending money I couldn't afford..Now I feel its pretty well built Im trying not to spend money on it..occasionaly I see something I just can't resist and I buy it and it sits in my shed ... I still want to and I definitely get withdrawelz from not driving it...I crave it, I long for it ,im breaking Into a sweat just thinking about it....
Artz go and drive it ya big skirt.
evo is quick.. im gonna miss that being able to put the fut half way down and all of this boost noise and power to release and get that flutter...
once i buy a house, you all need to force me to get another jap car
then I remember sitting at the lights on st kilda rd (near fitzroy st) and this guy pulled up next to me in a brand spanking new (well close to) Wine red R33 Gts-t... and the rest is history
yeah, I have a dump and front pipe sitting there... just need to find an 8MR turbo and BOV then I can wind in more... should be looking at 230ish which will make a huge difference
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
