relationship advice?
Yep
What happened Matty?
Spoke to her last weekend, said I'm not gonna have any regrets, so just one last time, do you want to try again?
She said No. Had a bit of an argument, got upset, next day thought "f**k you" and started moving on. Today she messaged me about picking up her shit then wanted me to drop it off, I said No. Of course she started an argument over it and resorted to insults, and I didn't. I didn't give two f**k's, I felt nothing anymore, and I loved it.
Add in the fact that I'm seeing a f**kin cute as f**k chick this weekend, 10 times hotter than my ex... yeah, I'm already happy :P
Great to hear mate, it'll only get easier too. Sounds like you got closure from the "no regrets" thing, pushing all the blame onto her.You may have a relapse or two along the way (hopefully not), but stay strong - they will disappear in time and keeping yourself distracted is a great way about it. If you start thinking about her or get the urge to communicate again, just think about all the things that pissed you off about her and how she hurt you during the break up.
Don't fall into the trap of comparing new girls to your ex, as is common after a recent break up and can bring up feelings you don't want. Just have fun and enjoy the good parts of being single. You never know when you'll meet another one worth keeping!
And...it's completely normal to always have a soft spot for someone you once loved...when someone is a huge part of your life for so long, there will always be memories and nostalgia. So don't feel bad about that if it happens.
:cheers:
I'm like 178cm ~90kg and I wear a 52......
... I... I don't know brah. Didn't try 48 since 50 felt pretty damn snug... Could try when I go back but :O
edit: also probably not some ripped unit like you.... yet. (A LONG WAY AWAY "YET") :P
You might be alright mate. I'm snug in a 52 and 187cm, only 80kg. Body shapes and brands vary so much. Just make sure it's tight, but allows you to move around on a bike. Pas had me sit on a bike at Peter Stevens, which you should do to get a feel for if the gear is too restrictive. And remember, it will loosen up over time. You're doing the right thing :thumbsup:
Dezz has huge legs if I recall correctly.
Yep
fuck bitches
get money
Oooh, that's an idea. When I go to make my purchase I might ask if they'll let me do just that :D. Yeah with the loosening up considered, I was edging towards the 50. Also it had the insert liner thingy you could take out for summer, which frees it up a little? Plus my cut continues... maybe factor that in... xD.
Cheers for advice though, liking the sit-on-a-bike-there-with-it idea.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
