Shingeki no Kyojin, havent watched ep 8 yet, i was surprised when
what i thought to be main character got eaten like that
dont show that spoiler alvin if you havent watched any of it yet.
i've already been spoiled by sankakucomplex, so not a big issue, and i dont quite mind spoilers anyway.
ill have to take you for a spin sometime... when its running again :(
baffled sumps for FWD SR20s dont exist, wew.
Accusump? might struggle for room in engine bay.
Dry sump? $$$
if you are building it anyway it's not a hastle to remove the stock sump and add some baffles/wings
Yeah maybe just make some custom baffles
If they don't exist on the sr20 what are the track guys using?
If you not chasing that much power maybe you might not need it if you don't want to spend the $$
Yeh they do. They just aren't great, even mine had tomei baffles in there.
I think it's different with the sideways engine lol
plenty of designs for RWD sumps, but anything bigger than normal for FWD hits the crossmember. found some custom stuff for the Sentra platforms, but it's all old old forum posts.
mk, hopefully something just be made up in the one I got
it's a little more than 2 straight bits, they need to be hinged at the top so when the g stop the oil comes back in and have stoppers to stop it .
so they are generally deeper so the metal not hit the crank..and there not space to go deeper on a FWD..
Carsales strikes again:
Dude: I saw your NISSAN PULSAR on carsales. still for sale?
Me: Yes it is, would you be interested in seeing the car this week?
Dude: Pulsar?
Me: Yes the white one.
Dude: Would u swap for a skyline r33?
She eats prawns, so that makes things a bit easier :)
this...
let the semen flow through you
FYP
Get it, because he's gay, and has the gay sex. :rolleyes:
(Yes, this Tuesday feels like Monday all over again, I'm bored )
Dry sump? $$$
Accusump can be installed anywhere, but you don't even have a boot right?
FYP
You wish I was gay little man, you believe you would have a chance.. You want some of this brown sugar don't u
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
    • These look like S13 wheels.  And Welcome!
