I'm tempted to login to his webmail to see if/what his manager responded to him with. Don't mess with us I.T folk we have our ways :P I wont though.. have morals!
bs, if there are no logs of you checking it, there is no harm.
if you ask for help and then refuse to listen to what help you are given , support turning around and making your life hell/stabbing you in the face with a rusty fork is entirely within reason.
there would be logs..but every good sysadmin knows how to sort them out
Bout $25.
:woot:
do i look like i am made of money , do you think I have a f**king money tree growing in my back yard in my Toorak mansion...is my name Steve Jobs...
i'm from Frankston mate where I can get a repco filter and a 6 pack of beer for 25$...how dare you try deny me beer... :domokun:
I used to get people banging on about the drift ones at Autobarn all the time... Because there is a magnet in them.
I would tell them it's just a gimmick cos if your magnet is covered in metal, it's clearly too late anyway, but for some reason they would still "need" to have it lol
K&N is worse.... That shit is soooooo overpriced but if someone wants it there is NO changing their minds.
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
