yeah suspected getting ripped off, but wasnt surprised. that car an I have been through some rough times together...
554217_10151100983246929_1461739437_n_zp
they tried to do me for the windscreen wipers but they changed them when it got serviced like 4 weeks ago "oh... well ive only got 1 put down on the list, so must be the rear wiper..."
  • Like 1
Looks like the side of my car after DECA :P
Think I'll give him a wash tonight...
Ha, bullshit, he just made that shit up... I'd be paying $10 for new wiper blades instead of calling BS and having him "find" something else more annoying
I wonder what sort of time ill get on Friday at heathcote. Won't be launching too hard off the line to preserve my tail shaft / input shaft :P
Should shit out an 11 easy just depends how low 11!
Edited by UNR33L
drive it like you stole it top bloke
Dem falcadore excuses already brah?
rally bashing?
i had had mad fun in a stat write off camry rally bashing it, had rear ended someone so required some chain or rope to keep the bonnet down and the crash caused the factory radiator to become a V mount.
gave it side pipes for lulz and then slid it into a few trees and such. tops fun.
what clearance?
police check?
financials?
Top secret?
Neg 1?
Neg 2?
Not sure but it's from The Australian Government Security Vetting Agency..... will be working for DMO, a department of the defence force.
Wash mine too while you're at it.
Nice work. Mate of mine works there I think (or maybe it's DSD)
I've done one of the security clearance things, it's long but you just have to cop it lol
rally bashing?
oh man sides pipes... i wish.
No rally bashing, that was the result trying to escape from a camp site in Murchison after heavy rains. Carry speed through the edges of small swimming pools and ankle deep sloppy mud is the only way to get through. Pulsar pulled through. However I was in the mud in pitch black trying to get out a bogged yaris. Women/men who are not confident in driving through mud and wont listen to instructions shouldnt drive through mud.
they were less practical than the idea was before we did it.
if you sat still for too long you nearly choked on the exhaust fumes, also the only way to get them out the side was to run under the chassis rails, that meant when ever you hit a big bump/rock you tried to rip them off the car or left massive dents in the pipes.
should have just taken the exhaust off at the headers/cats instead.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
