I'd argue that it's more important in brainless movies like I expect this to be, that the plot "twists" are a surprise. This is more of an Easter egg deal that I know I would have enjoyed finding out in-movie
you mean like "Mia I'm a cop"...that wasn't really a plot twist...unless you were Mia...then it was like SURPriSE!!!
Told her its up to her, if she wants to move forwards and away from his bullshit then I'm happy to help her do that, but the only way it's going to happen is if she puts some effort in and cuts contact with him...
If she doesn't want to do that, then I'm out.
Last night she was asleep next to me on the couch, I was going to get up and leave then sms her with "Sort yourself out over the weekend and call me when you've made a choice about what you want to do with your life"... then she woke up as I stood up. Fuuuuuu.
She said I'm distant a lot of the time, I said I couldn't completely open up to her while it was obvious that her heart is split in two... Boom: Reversal.
She knows that he's a horrible person and is bringing her down, and she knows that I'm a good thing in her life. So it's up to her to make the choice, I'll be there to move forward if thats what she wants, but not if he will be involved in any way.
You sound like a pretty nice guy Simon, she sounds silly.
I know right, I'm f**king amazing
So what's the deadline for her to sort it out? This weekend? Have you told her that since you didnt get the chance last night?
I'm not going home to her tonight, I'm staying at my parents place... That bed will be pretty cold without me.
She'll probably call me tomorrow to see what I'm up to, depending on how I feel I might leave her on Saturday night as well.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
