hahahah. i meant the ones by hands... you screw up something early on, and then you need to recalc, look through tables again, and do all sorts of ceebs shiet. even worse interpolating, gah.
else have to matlab or some shiet for non-hand calc ofc. also not a fan :P.
doing a few questions on some airframe loads... iterations done and then READ FROM A GRAPH... initial c_l is like 1.113... after iterations etc you end up with c_l = 1.099, as if you can even read that difference on the shitty resolution graph they give you, all for the "huuuuuuuuuuuuuuge" difference it makes in your final answer...
hahahaha my knowledge of matlab is sketchy at best, i'm pretty good at simulink, but that's all.
you know what's f**ked up? ANSYS.
Don't ever mention ANSYS again! Bringing back my nightmares mang!!!
Yes that's a 156HP @ 183KG naked bike <3
$19,990
New price? If so, not bad for MV Agusta. Of you're going to spend that money, I reckon a Ducati Streetfighter is where it's at.
Or Speed Triple / Z1000 for nearly half the price...
Or a Monster 1100 EVO...
Either way, get another bike and this time make sure it's big and trackable.
sot sure if 1960's rock band........ or 2013 hipsters
i have read the posts.
hamish, rebuild the 991 3.6L and stroke/bore to 4.0L. first world 1% problem solved.
yes but i was thinking I could have the auto one for a daily and the RS 4.0 in manual...
Obviously I will need an RWB 930 track car aswell... I know it's more expensive to do it this was as I will have to buy 3 x prosches but I really do think it's the more logical option
combine reiteration question with
*insert typical engineering problem solving.jpg*
LOL
I would only go to that much effort in an exam. Every other time i'd be just meh. Or use answer from book and work backwards :P
Toby can I claim a bunch of stuff as business startup costs even though business hasn't made any legitimate monies. :P
Ed...actually.dont worry just remembered I don't need to claim anything..
Business startup costs have specific deduction requirements and claims. Its a bit complicated if you plan on doing it yourself.
Still a good idea to claim, so you can carry forward losses. Prob should be registered for GST too if you in losses
Need a big return again this year Tobes, got a lot of concreting to do lol
As long as you got receipts for your claims :P
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
