So...you're going to buy one then?
probably, need to sell my bike / get tax return first though
long story short, my bike is up for sale again dude that came on weekend pulled out
those IT guys.... got too much cash lying around.
not really, bit above average income just live at home lol
Q: Why are a fifth of Americans unable to locate the U.S. on a world map?
A: 'I personally believe U.S. Americans are unable to do so because some people out there in our nations don't have maps. And I believe that our education - in South Africa and The Iraq - over here in the U.S. should help South Africa and The Iraq and the Asian countries to build up our education to improve our future for the children.'
wut.
Yeah but you asked me for the purchase price of my car, which I thought was for depreciation or something? I bought a new (used) car in Oct/Nov so was just wondering if that changes anything else
Apart from that it should be as easy as editing the spreadsheet I sent you last year with some new figures for tool purchases etc
Oh yeah I got a bad memory. Nothing much changes apart from depreciation
Also saw the video of the Miss World, Provides some lulz
Ah okay!! I'll have to give it a shot once they're on. It's an r31 with an rb25 conversion so I need r33 brakes to engineer it and iv got 4 stud hubs so wheel sizes are limited, I'd prefer to run 15in steelies.
Because I was bored just sat DC2R stocky over my brakes, something with a fairly flat inner barrel should fit alright, it'll be tight but there's clearance. Wheels with a deep drop centre or stepped lip probably won't even come close to clearing though.
Thanks for that mate. I'm hoping theres a chance they'll fit. I'll get it done and try.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
