It is with great sadness to report that I have accepted a new job in Perth and will be moving permanently.
I will commence work by end of July so the next sauvic meet will be my last :(
It has been a big decision but it seems to be the right choice to develop my career.
I will miss you all brothers :(
Thanks for all the memories & laughs.
/4 weeks and counting until judgement day
f**k! Congrats man!! Should definitely organize a proper send off
Wow! Congrats anyway man
its coming across, only the weak sell up!
/tilldeathdouspart
I've heard perth isn't as strict in mods so you can go a bit crazy on 32 :P
Picked my Desmonds up from Import Monster today
Makes me sad I;m selling straight away though
yeh think Josh's GTR has like 350awkw or something, used to have more AFAIK but had problems and needed to rebuild again
either way, duno how a 200kw falcon could beat it hamish your mate must be an idiot lol
has cams so sounds mad as well
yeah pretty much.. he's more of an associate really...
he's got a couple of mates with FPV GS's and for some reason the fact that they have nearly 400rwkw and he goes cruising with them means his car is all of a sudden unbeatable
every other day he's posting things about his drag race conquests on f/b that I don't believe.
he did mention the car was making a lot of "noise" which would be the cams.
ahh and maou is over, by far my fav series of this season.
im putting off watching the last ep. all the action episodes are so generic... domestic disputes and comedy are what the show does best.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
