I'm no expert on the physics of flow and pressure, but I would think that regardless of length (to an extent), once a tube has been filled with air or fluid, then changes in pressure should be near instantaneous at either end?
Alvin?
Alvin?
Think of it this way..do you want air pockets in your brake lines?
some fluids are very im-compressible so yes the pressure change would be near instant.
something more compressible ie air, it's going to take more to impact it, your going to have to change the pressure of a much greater volume so I would expect lag to increase.
plus same goes with zorst gases getting to turbo they have to travel more distance.
But in having more distance to travel there is also restriction too, so whatever detriment it gives to spooling the turbo, it could help with the engine building up RPM too?
It is external gate...
As the turbo is 4-5M back from the engine it shouldn't get too hot, there will be a heat shield over it all, and hopefully carpet back over the lot. I have to test it with an infra-red thermometer on the dyno first.
Lol something about a turbo sealed in the boot makes me feel uneasy.
That is going to be a lot of heat and no doubt the hot air will enter the cabin area.
Cut into the floor of the spare wheel bay and set up some cold air feed
Alvin?
i'd say there should be a little lag with regards to spool but, nothing serious. 4-5m isn't that long. As air is a compressible fluid, at even at scotty's 45psi, that just resolves to 3bar, which does nothing for compressibility, so there will still be an effect, though, pipe length is a lot less of a factor than a restriction.
But theoretical vs physical, i still think scotty should give it a try.
Don't worry, I will be. :P
The turbo won't be laggy, the engine should have the .82 rear GT35 pushing 20psi by around 2.5k, but it may not be as responsive as it would be hanging off the manifold...
The piping up and back is 2.5 inch so not too much area to fill.
Haha, days off important too :P. What is not good is when you take days off, and then unexpected events mean you can't go on days you were planning to go !
Also gotta figure out if it is indeed just my bulb that has burnt out in my headlight... if it is... china bulbs off ebay, $10... phillips like $67+ ... DECISIONS... Not sure if trust quality (+ shipping time probably like 2 weeks+) ... but then dat money =[
    • My theory would revolve around the ~4000rpm point being peak torque territory on an RB, where you're supposed to be looking at max efficiency of the head, etc, and....just not having it because the skinny ports are doing something to f**k it up. I'll admit, it's a loose theory.
    • It could be in the tune but in both cases it couldn't be completely solved or eliminated by some of the best tuners in victoria so I'm DOUBTFUL that it's in the tune or ECU but stranger things have happened of course. I've pondered that theory too but is there any theories that thinner and smaller ports overall would cause a turbo to spike? I would've thought it would just restrict it in general if it was small enough to make a difference. I wouldn't expect it to make a different at what is essentially sub 300kw at 4000rpm anyway. I think the next step is going to have to be the 6psi spring to rule out the idea that the gate is cracking open far too wide initially. At least that is the cheapest (free) thing to check initially.
    • I'm thinking it is skinny NA Neo port sizing and cams. Somehow.
    • -5’s did it. 8474 did it. Not hot side related. ECU related? 🤨🤪
    • Above you mentioned you only need to sand primer if there's an issue with it but with fillers it says the surface needs to be sanded to X grit beforehand. Does that sorta contradict that point as the primer hasn't been sanded yet? At the same time if I sand the primer, there's a good chance I'll expose the bare metal and I'm just chasing my tail at that point. Or I'll just use a sand sponge instead of sandpaper, it seems to be far finer in terms of abrasiveness as opposed to sandpaper. From what I understand, filler is like primer and needs scratches from the sandpaper to help it adhere to the panel. I realised the way I'm doing things is actually a bit counter productive as there's a chance after I put filler I will need to put epoxy primer again as opposed to putting the filler first and potentially no primer if I don't go to bare metal. Will keep this in my mind for the rest of my repairs.
