katoui... HOW f**kING BULLSHIT WAS YESTERDAY. f**k.
was soooo gee'd up to see him live... and his E30 in the background lol
Yeh :(
Was bull shit lol, we who got tix first didn't get a show, while extra show on Thursday did.
was gonna paint my rocker cover this weekend. did a practice run with the wrinkle paint on a piece of steel. It was flat and still f**ked it up... cant imagine doing it on small spaces. leave it to the pros me tinks
It's a cold weekend... Did you use a heat gun to bring out the wrinkle while it was drying?
yeah, did it in the sun yesterday and let it bask between coats then finished it with a heat gun. was gonna use BBQ for actual rocker cover, but seeing how uneven the spread was on the test subject, decided it would be best properly suspended and with decent prep-work since the cover is already painted, just chipped and starting to peel.
It's not that tricky... I just rubbed mine back with some of that green brillo pad stuff to get rid of the corrosion buildup, then wax and grease remover, then sprayed it with wrinkle black according to the directions on the back... Then hit it with the heat gun for a few minutes... keeping the heat nice and even.... it'll take a while, but pretty suddenly it'll reach the dryness point where it starts to wrinkle... you'll see it spread over the surface as you move the gun around.
Before:
705168_10151101013706148_1187555115_o.jp
Painted:
530994_10151101012971148_1067307599_n.jp
After:
I also did the crossover pipe, BOV and R34 strut brace in black wrinkle... and the exhaust manifold head shield in high temp black as well. Came together really nicely, looks clean and still looks almost stock until you put it next to a real stock car :)
I painted dat strut bar bro :P
I think with wrinkle the best results I've had have been cleaned & prepped well, preheated with heat gun so it's warm to touch then coats in the order it says on the can with 5 minutes and a bit of heat between coats, then heat as final and let it sit and cure for 24 hours or so, otherwiseeven if it feels hard it;'s still soft underneath the top layer and you can actually tear the surface and move the wrinkle leaving shiny bits if you're not careful.
    • Finally had these painted and fitted and pleased with the result. also managed to source 400R fender badges.
    • who can tell me what this is and why my car talks to me? i think it's hilarious. it's on my r34 right above the drivers-side storage compartment. the characters under the wrench say "inspection". every 10 or 20 startups, a voice starts talking in japanese from some speaker in this area below the dashboard. it says a few sentences then shuts off. different from the ETC card reader voice that happens every time i start the car. I've never found the speaker, i've never been able to catch the voice and translate what it says, and i've never found a forum thread that tells me how to reset the warnings. the holes in between the symbols are NOT buttons you can press to reset the warnings. anyone else have this? has the demon lord from Hereditary infected my car?!
    • Would you ever vent this bonnet or will it be unnecessary?
    • Happy new years folks! Wishing you all a successful year of money pit ownership!  So the subframe bushes are out....   Ok, who else has done that job before??  What a C U Next Tuesday of a job that is!  Be glad to not do that again in a hurry! I think I explored every option available to chop the middle section of the bushes out, most of them unsuccessfully! I tried a holesaw, die grinder, normal drill bit, air chisel, etc, etc. The true success happened by accident when I'd decided to try a step drill I spotted on the bench on the way passed.  See, there are benefits to never cleaning up after yourself! It RIPPED through so so much better than the drill bit. It has to be the skinniest one available so its small enough to fit between the inner tube and outer casing but it made easy work of it.  First one i hammered the shit out of... New method- 20250102_185506.mp4   I did the other 5 in less time than I fluffed around with the first one. With the first couple I used the cut off saw (sawsall as the yanks love to call them) to cut a break in the outer casings. Even with that they're still a prick to hammer or air chisel out.  The last few i just went rambo with the air chisel without cutting them. I over cut one of the early ones so will hit the with the mig to fill the cut then sand it off smooth.  The carnage left over-   I've also been "nesting" ie, cleaning up my babies nursery,  ie cleaning the f**king pig sty of a shed. I've got that much shit laying around it's as cluttered as my head!  Getting things put away, in boxes, on shelves, hanging off walls, all to get some working space back again.  Hopefully that keeps me motivated....
    • AFAIK does the base map for Haltech even have the 4D compensation enabled? It's been a while but when I looked at it I remember it was actually using pure TPS as one load signal and MAP for another. Seemed workable but not ideal by any stretch. A lot of people have "make the event-itis" which leads to stuff like this happening.
