Hmmmm DECA.... Considering Shockworks Coilovers and Whiteline Bushes before then... Wonder if its possible within a month, working full time?
Have already done the 4 Rear K-Frame and the 4 Diff Bushes with Whiteline goodness... So just Arms and a few other bits and pieces to go?
coilovers arent too hard to fit, but still needs alignment.
doing bushes DIY... yeah have fun with that :P
How do the shockworks coilovers compare the the BC ones?
Richo runs BC coilovers, seems to be good enough for him at the track
Coilovers I've got no troubles fitting...
Bushes, I'm not going to try ghetto remove any bushes that should to be pressed, ever again ;) Mike (Miguelone) and I spent a full afternoon trying to get the suckers out of my K Frame...
https://www.facebook.com/photo.php?v=10151330100116148&set=vb.641676147&type=3&theater
I've heard some very good things about them, local support is nice, they're only a few hundred more than BC BR's.
Currently I'm running Bilstein Shocks and Springs, I'm about 3cm too low at the zorst, I'd like something damper and height adjustable which is still silky smooth for the street (which my current setup isn't). Car was imported in 2006 with the Bilsteins on it, so they're getting pretty old I'd say.
Fair enough!
So now that your car is sorted when you coming back to the track?
yeah coilovers would be a pretty good upgrade. picking the right ones for daily use is the tricky part I reckon.
sif coilovers.
i got brand new bilstens and am getting eibach progressive rate springs.
silky smooth for daily duties and not too rolly for corners.
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
    • I'm shocked, you've owned a Skyline since 2006 and never joined SAU before now! 😮   Welcome, it's much quieter these days than it was in 2006, but lots of very knowledgeable ones lurk around here. I actually think in outage we've forgotten more about Skylines than anyone knows about them today... 😛
    • So it could give us some info. Such as we find out what number they started at, and we know how many of those blocks came before it.
