Vic Wasteland Thread
R31Nismoid
Quick question guys, need to do my gearbox oil.
Was thinking of getting some Nulon semi-synth from SCA or something, any recommendation?
Birds hook a brother up! Saw that you were an expert years ago in the gearbox oil thread.
Chuck in a better engine or a turbo, i'd be up there in the high 30's to low 40s with the s2000's :D
on rsr's..
you make me laugh..
current set-up you would be in 50's
more power mybe mid 40's
need semi's to get to low 40's in a FWD.
was watching the type r's on the weekend , mid to high 40's plus lots of spearing off...so sensitive to the throttle inputs.
lmao ric
nah i want to use it for winton as well, so proper helmet.
mate with stock novtec no swaybars drums got 47 on rsr's + coils.
I think i can crack 45-46 as is with bigsways/bigbrakes/ stiffer coils
Will be fun, so where to look for helmets, bike stores?
let me know if you find helmet.... i too am out of this months deca, as im on holiday but soon. i will try and drive my tank as fast as possible.
This ^
It'll look sweet coming through the smoke though....
Lol fakkk.
Hopefully no troubles with the new engine.
I was honestly so proud of myself when u thought I blew it up.
Osama would have been proud
Just go to any motorbike shop and find something comfy. Mine was like 150$
ive got a few bike helmets ion the garage... do the scrutineers check for adr sticker? ive got a tuv one from germany and a bs one from england, my aussie one is a bit tight for car work.
Shave off the beard.
My helmet got looked at during the 2011 nats, so i wouldnt chance it i guess.
right.... i love my European ones, but my aussie one give me a headache on the bike lol. spose i could take both and if i cant get away with it just swap....
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
