They advertise on the radio here about supercharger kits for your Holden and chipping your diesel for more power. Something you wouldn't hear in Victoria haha.
I wonder if there are different EPA laws in Perth.
Baby killers!
north side is bad mang.
Nah only your Coburg house was bad :P
Actually been going past it a fair bit lately lol
DNS / DNF
LOL!!!
Probably would be
But even in Vic the epa tests aren't setup to roadside the diesels (only petrols) so modding them is no issue. If your need to get an epa you must go to a the epa place
their rules are different, vic is by far the toughest on mods.
I have no experience with it, though Martini products are generally very good, so I doubt you'd see their name on something shit. I could be wrong, but from memory Martini are just rebranders of decent stuff from other manufacturers.
They make their own stuff now I believe according to mate who works there, ie used to sell endless 600 brake fluid, now have their own.
Engine and gearbox now filled with martini, yet to start it though. Motorbike soon to also have martini
Okay! I'm going to give Martini a go.
Cheers fellas.
Nope, one kit. "Hemnes" set of draws. Finished them off today. Found more issues.. One of the biscuit joins weren't drilled deep enough and pushed through the face side snapping the face of the draw. All the screws just keep threading themselves. Fixing sooooo many of ikeas f**k ups..
/whinge
Tl:dr
Yeh next time I'll just buy premade. Lol easier less problems or just build my own from scratch
sure you're using the right screws? :P
Prolly toughest on fines too
0-10kn/h over in WA = $75 fine / 1 penalty unit and no demerit points.
Same thing in Vic = $181 / 1.5 penalty units and 1 demerit point.
Consider how much living costs are between states and the gap is evidently larger.
No P plates displayed is also a lot cheaper / little or no points.
100% sure.
otherwise i would not have had enough/too many left..
plus, how could someone push a wedge through solid wood if it were drilled correctly lol anyway, its done now.. let hope it lasts more than a year lol
    • 65601-05U00 is the hood latch. 62550-08U31 is the support that holds it to the radiator core support. They are all super discontinued so I don't really have any great leads on how to source this stuff.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
