blamin the ATO just makes us feel better. it puts a face to the empty promises and hope we all cling to each year. the shadow behind the mask, personified.
I should write a play. 'Phantom Of The Tax Office'
inb4 it's your own money fgts...if you got buggerall or a bill then you paid buggerall tax or have a terrible accountant. Can earn 50k a year and get a 20k tax return if you want the ATO to hang onto it for you til tax time.
Those with less of a return are generally better off because, if they were clever and put their extra monies into interest accounts or wise investments, they made gains instead of the government getting rich off your shit. They technically made ~$90 off Leighs tax return.
And never plan your finances/bills/expenses around getting a good return...unless you can properly plan the return...in which case you probably don't need an accountant to do it for you.
/tobysassistant
The informeter tells me I hit 2.86 bar between shifts, when the auto fails to find the next gear in time for the soft limit. Generally 30psi pulls fairly solidly though. :P
Stock VQ25det FTW.
the skyline had a split vac line to the gate, stuck it on a dyno and it maxed out the dynos map sensor and my boost gauge. so it was somewhere north of 42 psi, the ECU pulled so much timing and added so much fuel it was shooting droplets of fuel unburnt out the exhaust and all over the wall along with a diesel like black cloud, dropped 100kw too for a mere 290kw run.
I had a similar issue a couple of years ago, wastegate line popped off and it ran 3bar+ for a few days (no idea how much as that was the sensor's limit.) It caused the head bolts to stretch and split the head gasket. Still no det, just masses of torque.
hm.
yeah i get what you mean, but the climate in vic is such that, driving a skyline means auto pull over the moment a cop spots you. probably not too worth it to be wasting cash modifying only to return to stock.
then again, might have something to do with me driving a yellow skyline.
    • My theory would revolve around the ~4000rpm point being peak torque territory on an RB, where you're supposed to be looking at max efficiency of the head, etc, and....just not having it because the skinny ports are doing something to f**k it up. I'll admit, it's a loose theory.
    • It could be in the tune but in both cases it couldn't be completely solved or eliminated by some of the best tuners in victoria so I'm DOUBTFUL that it's in the tune or ECU but stranger things have happened of course. I've pondered that theory too but is there any theories that thinner and smaller ports overall would cause a turbo to spike? I would've thought it would just restrict it in general if it was small enough to make a difference. I wouldn't expect it to make a different at what is essentially sub 300kw at 4000rpm anyway. I think the next step is going to have to be the 6psi spring to rule out the idea that the gate is cracking open far too wide initially. At least that is the cheapest (free) thing to check initially.
    • I'm thinking it is skinny NA Neo port sizing and cams. Somehow.
    • -5’s did it. 8474 did it. Not hot side related. ECU related? 🤨🤪
    • Above you mentioned you only need to sand primer if there's an issue with it but with fillers it says the surface needs to be sanded to X grit beforehand. Does that sorta contradict that point as the primer hasn't been sanded yet? At the same time if I sand the primer, there's a good chance I'll expose the bare metal and I'm just chasing my tail at that point. Or I'll just use a sand sponge instead of sandpaper, it seems to be far finer in terms of abrasiveness as opposed to sandpaper. From what I understand, filler is like primer and needs scratches from the sandpaper to help it adhere to the panel. I realised the way I'm doing things is actually a bit counter productive as there's a chance after I put filler I will need to put epoxy primer again as opposed to putting the filler first and potentially no primer if I don't go to bare metal. Will keep this in my mind for the rest of my repairs.
