PATRICK
Leesh just got defected. Window tint 1% darker than legal; window regulator faulty. Inb4 WA is next Vic.
Ahhh you think moving to Perth is your ally...you merely adopted the defect. I was born in it, molded by it. I didn't see a roadworthy until I was already a man; by then it was nothing to me but COSTLY
yea but in WA, you DO NOT have to open your bonnet when they ask.
keep it visibly legal and its all good.
Grant wears a strap on. Beware
Welcome abroad, strap on, it's wild ride in here!
That is one shiny car brah
Tradition on here is to take a shirtless pic in the reflection of your car
So we know how good your detailing is
nohomo
okay so nohomo...with the talks of strap ons...I is confused :P lol jks, thanks guys, car is dirty as fuark tho.
Also, followed by marked divvy van for a bit just before, didn't get pulled over, winning! :yes:
^Well, that's Friday for you. Drove the lancer down to thai to grab lunch... Bastards closed until 4:30. SHATTERED. At least I got a drive in :P.
Also went to vicroads... stamp duty is such a money grab.
no worries, i did scotts ones swell
Awesome. Let me know what times etc work best for you and we'll sort it out... but like I said I'm in no rush as of yet, so :P.
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
