yeah but she has never run out before
It was weird when it happened, it was like she had this huge gust of energy, but she was really out of it from all the seizures so she ran off
while she was down the back we couldn't even pat her cause she didn't really even recognise us, would just growl and if you got to close try to snap at you
Nick dude, I'm probably gonna get flamed for this, but why didn't you euthanise her? It sounds like she was sick enough for it to be justified.
Good luck with her I really hope she turns up or at least passes peacefully. Dogs are family members.
Older brahs.
Going through a crisis.
I dont want my car anymore.
Im considering stripping it.
Ill keep the wheels, skirts and pods and rb26 but sell all the other shit.
I used to love that thing so much. Doesn't seem that important anymore.
Haha good ol' Mohsen.
In b4 he sells the lot and buys a vl :P
strong future aware.
The thing is were we about to that day, we knew she wasn't getting better so we were going ot take her back to the vet that night
But then she got up that morning and took off, it was the weirdest thing. As if she knew we were going to take her
Thanks though man. Yeah they are, they make such an impact. But even in her eyes her personality had gone :(
we euthanized our German Shepard after she lost control of her hind legs. Loss of control happend so quickly, could no longer move after 2 days, whole episode happened quickly.
I could imagine it would be a much harder decision if you have a hope to prolong it etc
who's on optus here?
i've been on telstra only for years now, but optus have readjusted their plans to be somewhat in touch with the current technology (more data)
well....you know my issue with optus lol
I decided to stay with them after their offer through ombudsman.
Will stretch it out a couple more months & transfer to telstra
Ah k, fair enough man. My family have probably spent the better part of 100k on pet bills over te years...we're all for doing everything we can for our loved ones...but we also recognise when we're fighting a losing battle and know when it's time to make the call. Have had to put down at least 4-5 dogs...it never gets easier. Memory issues are fking sad too, like Alzheimer's in humans...terrible disease.
Just remember the good times, as they say. Knowing and remembering that you gave an animal a good life before it's passing can be a reassuring thing. Talking with family members about your memories with your pet, is also good catharsisism.
She wasn't declining so we were hoping she would improve but it didn't happen
Yeah that's why we were hoping she would improve, to prolong time with her. But we knew we would have to euthanize her, but then she went weird that morning and ran off. It's actually worse not knowing where she is or what's happened to her than having to euthanize her, at least you can bury her at least
    • Great interview on damper settings and coil selection by HPA https://www.facebook.com/HPAcademy/videos/30284693841175196/?fs=e&s=TIeQ9V&fs=e
    • Yeah, it was a pretty deep dig.
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
